New kioti or used?
/ New kioti or used? #41
If you are looking for a used box blade on craigslist use can use search tempest or a app on your phone to search for you. If you want to watch auticons you can look at auctionzip.com to see if one pops up. I agree that under normal conditions a compact tractor will not tear up a light duty box blade heavier one will do a better job and make a better ballast.
/ New kioti or used? #42
Just as you have ballasted your tractor to get the weight up to 5000lbs, it is possible to ballast a standard box blade too.
The difference here being that according to my owners manual, the tractor can be ballasted up to but not over 5000lbs. The tractor has the strength designed into it to handle the stresses that can be exerted with that much weight.
I have NEVER seen a box blade where the manufacturer says to add weight to make it perform better. :confused3: The lighter duty implements are fine for their purpose, but to add weight and expect it to do the work and hold up like a heavier implement is foolish IMO. ;)
/ New kioti or used? #43
Each to his own. However, just for anyone who is interested, here are a few examples of guys on TBN and a dealer who have suggestions and examples of adding weight to a standard BB:
http://www.tractorbynet.com/forums/projects/249062-adding-weight-underweight-box-blade.html
http://www.tractorbynet.com/forums/attachments/157372-box-blade-weighting-do-you.html
http://www.tractorbynet.com/forums/build-yourself/143436-adding-weight-box-blade.html
Weighting a Box Blade
http://www.mytractorforum.com/showthread.php?t=38058
/ New kioti or used? #44
I guess that I'm missing something. :confused3: Was there a box blade manufacturer listed in one of those links that showed that it was ok to add weight to their box blade? I must have missed it if there was. As far as Carver, there main thing was concerned about using the box blade with added weight for a loader counterbalance and mentioned that the box would perform better being weighted.
I still have not seen any manufacturer recommending to add weight. Doesn't really matter, yes an average BB will work better with additional weight. Good luck to those that do it and get by with doing it, they have saved themselves a bunch of money. :cool2:
/ New kioti or used? #45
I would think if they intended for you to add weight they would have a weight box on the BB or a option.
/ New kioti or used? #46
Adding weight is common. Carver is a very large and well respected tractor and implement dealer. When they have a full webpage describing how to add weight to a BB I think we can assume it is mot a harebrained notion.
Of course the manufacturers would prefer you just buy their heavier model and that makes sense for commercial use. Manufacturers don't like to cannibalize upgrade sales by making it easy on us.
/ New kioti or used? #47
In that entire write up, this is the ONLY mention of using that extra weight for grading. (A weighted box blade performs better than one without weight, so you enhance the "implement" as aspects as well.)
That whole write up made contant refrences for the weight adding counter ballance for use with a loader, it was not a write up saying to do this to make your light duty implement work better. More like "by the way, the box blade performs better with the additional weight that you have put on it to counter ballance the load of your FEL.
We are going back and forth about nothing important other than our own perspectives, so I'm done, your right, you win. ;)
/ New kioti or used? #49
Alright then, I'll just chime in with this.. My CK25 with a cheapo 5' box blade can be stopped when the box gets a good bite, not talking stumps or rocks, just dirt. Especially going up hill.. I don't use ballast, but my point is even light cheap boxes can bite off more than you can chew. I think for a first BB, a cheap one is a good choice. Had mine five years with no complaints, not looking for a heavier expensive one.
ps. isn't a commercial one called a dozer? :D
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2014 Hagie DTS10 Sprayer (A63111)
2014 Hagie DTS10...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
Massey Ferguson 9250 (A63688)
Massey Ferguson...
Kubota Snow plow with subframe
Kubota Snow plow...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
