New kioti or used?
/ New kioti or used? #21
Bullitt, mtnv, can you recommend a few? Everything attachments? Or others. If I could finda used one close idchave no problem picking one up.
Just my opinion here, but the ideal width for your tractor is 66". These are hard to find, but if you can, that width would serve you best IMO. I would go with a 60" wide unit before a 72" box, but many TBNers say that they have good luck with 72" unit. I prefer to have the tractor work the implement vs the implement working the tractor. Now this is not to say that I want a smaller lighter implement. The ideal situation is to get an implement that is big-heavy-strong enough to get work done and can be used to it's fullest capacity while taxing the tractor vs having a bigger implement that the tractor can only rarely use to it's capacity.
I would not get any box blade that weighs less than 600lbs and an 800lb box would be better. Look at boxes that have a minimum of 3/8" thick sides. I can't really help out with any brand names, there are many that have light, medium & heavy duty units. I am pretty sure that ANY Gannon of the right width would be fine, but that most likely would be a used unit. Don't be afraid of a swinging rear blade on the box either, can actually be a benefit when used properly.
Good luck ;)
/ New kioti or used? #22
I think a 66" would be good for your tractor but it will handle a 72." A 66 is wide enough to cut the tire tracks. Something like a bush hog MBX, or a land pride MR would be good. I had a light duty 6ft on the Bobcat CT235 I had. You may get lucky and find a real heavy duty used box blade. If you had one that weighed 800lbs it would a real good ballast for the FEL.
/ New kioti or used? #23
My Mahindra 3215HST is very close to the Kioti CK35. In fact it had come down to either the CK35 or 3215 for me back when I was looking for this size tractor. My tractor is ballasted to about 5000lbs. I run a Gannon 66" roll over box blade with it. They are what I would consider a perfect match size and weight wise. I also have a 72" Gannon with a manually actuated ripper bar (vs a hydraulic actuated ripper bar). I believe that the 72" BB weighs about 1000lbs. It is too much for the tractor to use in all conditions where as the 66" unit is "just right" in my opinion for my conditions and circumstances.
Other peoples uses and conditions may vary so that a 72" 1000lb box blade would be ideal for them. Different conditions are one of the many things that are so often forgotten or not even thought about here on TBN.
Good luck with the search. ;)
/ New kioti or used? #24
I think you need to consider the size and weight when sizing a box blade to a tractor. A tractor may pull a 450lb 6ft but not a 1200lb 6ft. That heavy box blade will cut in were a light one just glides across the surface in spots.Usually the heavier box blades hold more material so they will pull harder.
/ New kioti or used? #25
Very true and one of the things that I often forget about :eek: because I typically only look at commercial or industrial grade implements. ;)
Billet and mtnv. I'll defiantly look for the heaviest one I can find (within reason $). It doesn't look like the united brand bb's are heavy enough at a little more than 400lbs. For a 60".
/ New kioti or used? #27
If you can hold out you may find a used one at a good price. Check craigslist and ebay.
/ New kioti or used? #28
Landpride
/ New kioti or used? #29
Just a quick counterpoint on the box blade weight: there is no question that weight is important but the downside is that heavy duty box blades are very pricey. They are designed to stand up to commercial use and cost easily twice or more what a "standard" duty box blade costs. A 35hp tractor is not going to destroy a standard duty box blade so one cheaper option is to get a standard duty and then add weight to it. It might take a little fabrication work to build a platform to hold bricks or steel or concrete blocks but that will add weight. Again, you don't want to try that with a 100hp tractor but with a CK35 it should work fine.
/ New kioti or used? #30
I'm with IslandTractor.
I use a 6' King Kutter boxblade with weights on my DK 35 and it works fine.
/ New kioti or used? #31
You have a very good chance at tearing up the implement if you add weight to it.
/ New kioti or used? #32
Really? With a 35hp tractor?
A 50hp CUT doesn't tear up a standard box blade so I don't see how the 35 would. The added weight (probably 200-400lbs) just keeps the BB from skipping along the surface.
/ New kioti or used? #33
I put @300 lbs on my 6' box blade on my little l2800 and it makes it work much better and I think it will stop the tractor before I hurt the bb.
/ New kioti or used? #34
It's not just the HP rating, I have my 32HP tractor ballasted to 5000lbs. That is more weight than a Kubota M7040 4x4, about the same weight as an M8540 2wd and only 400lbs less than an M8540 4x4. Do you think that those tractors should be using an implement that is made from 1/4" material? :rolleyes: A LOT has to do with what, how & the conditions of what a person has to work with.
IMO you never want to add weight to an implement. When you do that you have just increased the capability of that implement past what it was ever structurally designed for. Do the light duty implements work? Yes, do they work as well? Usually not as well a the same implement that is built better & heavier. The size, weight and cost of any implement all need to be evaluated when being purchased. What many of us do is recommend what would be the ideal setup and the rest is left up to the guy paying the bill. Nothing wrong with saying that a person can get by with something light duty, but it is nice to know what goes along with whatever is recommended, good or bad.
Just my :2cents: based on what I have seen, read and mistakes that I have made from inexperience over the years. ;)
/ New kioti or used? #35
I agree with MTNview.
If you buy a good tractor why not buy quality implements for it. Alot of the time you can find a used implement that is like new except it needs painted.
/ New kioti or used? #36
I agree with Moutainviewranch and 94Bullit. I recommend you get a good heavy duty 66" boxblade that doesn't need extra weight added to it. Put your money and the weight into the structure of the boxblade. I would also recommend buying the topntilt kit from Brian (Fit Rite Hydraulics). I spend lots of time doing boxblade work and it is much easier to hold a grade with a heavy well built model.
/ New kioti or used? #37
Yep. Go heavy. I found an old gannon 6' that was all orange with rust for $150. It's the real deal, with 8 scarifiers on a single retractable bar and pivoting rear blade. Guessing right at 1000 lbs or so. It was missing the rear blade and needed a little welding. With the new blade, welding, and fresh paint, I'm in for about $400. But, the blade I have easily would cost over a grand new. It cuts and spreads great, even on my little CK25.
/ New kioti or used? #38
If I found a heavy duty box blade for $400, I'd buy it too. However, unless you want to search Craigslist constantly or hang out at farm auctions, the only alternative is to buy one new. As I recall, a standard 72" BB can be had for a bit over a grand from Woods or other quality manufacturers. Heavy duty BBs are at least double that. So while heavy is good, adding weight to a good standard BB is still an economical alternative for non commercial use. And, you can use the extra grand you save to get a grapple or other extra implement to increase overall tractor utility and efficiency.
Edit: Gannon makes the heavy duty Woods BB. I believe they are actually closer to $3000 in the 72 inch >1000lb size. Don't be fooled by the many companies that call their 400-500lb box blades "heavy duty". That is marketing hype. Nothing under 1000lbs, even in a five foot BB, is really heavy duty.
/ New kioti or used? #39
Based on that statement, a 60" heavy duty BB does not exist. I found a Gearmore 2G2 series 60" industrial BB that weighs 770lbs, but you are correct in that it is not rated to be "heavy duty". It is only industrial quality (about twice as heavy as the next step down) and what about every landscaper around here uses. Some people would prefer to have 1 GOOD implement while others are happy having 2 average implements. All that I can say is "each to his own" and that the average implements do indeed work well for many people. ;)
/ New kioti or used? #40
I think that as you and I have both discovered, the use of the term "heavy duty" is pretty lax when describing box blades for marketing purposes. When I think heavy duty I think of the >1000lb Gannon type BBs which are truly commercial quality (I cannot imagine why a private individual would want to shell out three thousand plus bucks for one). These true commercial heavy duty BBs also typically have other features like roll over etc that might be nice but are infrequently used by homeowners etc doing driveway maintenance type tasks.
I certainly agree with your comment about having one good implement rather than two average ones. I'm not advocating buying the cheapest mail order box blade you can find. However for me a good box blade is a Woods SR72 (standard duty, about 450lbs or so and about $1000) and that is strong enough to stop my 5000lb+ 40hp tractor dead in its tracks when I hit a stump or big rock. Strength of the SR72 is simply not an issue. Weight of the BB is as you often point out a very important part of making the tool work but my point is simply that inherent implement weight is not the only way to reasonably get that total of 800-1000lbs of down pressure. Just as you have ballasted your tractor to get the weight up to 5000lbs, it is possible to ballast a standard box blade too.
CASE INTERNATIONAL 183 - 6R DANISH TINE CULTIVATOR (A63291)
CASE INTERNATIONAL...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
1999 MACK MIXER (A63569)
1999 MACK MIXER...
2014 Mercedes Benz CLA 250 (A61574)
2014 Mercedes Benz...
