MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,712
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Bullitt, mtnv, can you recommend a few? Everything attachments? Or others. If I could finda used one close idchave no problem picking one up.
Just my opinion here, but the ideal width for your tractor is 66". These are hard to find, but if you can, that width would serve you best IMO. I would go with a 60" wide unit before a 72" box, but many TBNers say that they have good luck with 72" unit. I prefer to have the tractor work the implement vs the implement working the tractor. Now this is not to say that I want a smaller lighter implement. The ideal situation is to get an implement that is big-heavy-strong enough to get work done and can be used to it's fullest capacity while taxing the tractor vs having a bigger implement that the tractor can only rarely use to it's capacity.
I would not get any box blade that weighs less than 600lbs and an 800lb box would be better. Look at boxes that have a minimum of 3/8" thick sides. I can't really help out with any brand names, there are many that have light, medium & heavy duty units. I am pretty sure that ANY Gannon of the right width would be fine, but that most likely would be a used unit. Don't be afraid of a swinging rear blade on the box either, can actually be a benefit when used properly.
Good luck
