New JD4520 cab is destroyed
   / New JD4520 cab is destroyed #11
I think I would get the agent out there before moving that stuff. That looks like alot of damage from all the pics. That front cooler is for the intake air, sure wouldn't want to try and start it and pick up any trash in the motor.
Wish I was close enough to help you out.
   / New JD4520 cab is destroyed #12
Very sad to see neighbor.
Grunt
Steve, No way I'm starting it, and I'll be disconnecting the batter when I go back out in a few minutes. Dealer needs to check out and own everything so the repairs and (hopefully) original tractor warranty are intact.
I want to get the snow and ice off the roof sections to stabilize it, and I need to get access to put a tart over it for rain Tuesday. Monday I'll talk to the agent and see how much work that affects the structure directly resting on the tractor he wants me to mess with. There is also some cribbing I can do so things don't shift.
tnx for the kind words, Grunt!
time to get back to it...
Pete
   / New JD4520 cab is destroyed #14
I agree with stabilizing and tarping the whole thing, disconnecting the battery is a very good thing to do first. Don't get yourself hurt either.
   / New JD4520 cab is destroyed #15
This would be a good time to get a couple of your volunteer firefighter buddies to help out. Some of those timbers look to be pretty good size (and weight). Definitely not a one man job to do safely...even if the other guy is there just to provide a safety watch.
   / New JD4520 cab is destroyed #16
Oh man... that's a bad "sucker punch"!! Definitely take the wind outta your sails to come home and see that!
But... from what you can see in the pics - it doesn't look like a fatal wreck. The worst looks like the right side ROPS in the cab. The barn beam may have bent or tweaked that a bit.
The rest appears to be only "skin deep" and with some new parts should be as good as new.
Keep us posted on how you (and the tractor) come out.
AKfish
Got all the snow off the tin, and some of the tin off too. The roof went from stiff to bouncy, so everything is stable with 1/2 the weight on it as it had this morning. I'll put a tarp over it tomorrow.
I plowed my neighbors driveways yesterday for them, one is a firefighter. They came over and helped. Funny how those sorts of things work out.
There is one main beam on the right rops holding up half of the mess, and the PHD on the tractor is holding up the other side. I'll let the insurance guy make the call, but it does look like great rescue training for the department. Roy is right- this is a very tricky technical rescue (of a tractor). If what is left fell on someone, they probably wouldn't survive.
Damage seems to be the front AC radiators, hood, two glass sides of the cab, the top molding on the cab. Oddly enough, the metal top is good. 3 pt hitch lever is bent a bit and the molding for that side is gone. But the underlying metal work seems good. I'm assuming the tilt is the weight of the structure.
I wish I could accurately describe or photograph the way the shed post split so it was resting on the ROPS bar, with a big piece of beam balancing out one side, the PDH and sickle bar holding up the other half of it all. You could spend days trying to get this to balance out that way. That is also why it will be a tricky recovery.
I'll post on this thread how it all goes with the insurance, the Deere dealer, and what it takes to repair it. It's stable for now. Only got about 3 hours sleep last night after plowing all day, so a little rest is in order. It gets down to 10 here tonight so I just hope everyone stays off the icy roads (which as the call I was on last night when all this collapsed).
Nothing squishes like a Deere.
Pete
Here's the view of the shed from the house. Not what you want to see in the AM. Note the little green roof the tractor that was inside the shed.:eek:
The whole shed went south (literally in this case) at once, and just folded evenly on one side and landed on the ground. The main roof just missed the tractor and the overhand section is what landed on it.
Know everyone likes pictures, just thought I'd toss in this one.
Pete
   / New JD4520 cab is destroyed #19
Man that is awful to see being a fellow deere owner and also having a brand new tractor mine only has 6 hrs on it. I would have said a bunch of bad words when I came out and seen that. Its great that it happened after you were out of the shed and you were not hurt . I would like to know who your insurance co. is because I had to get an extra policy on my tractor? My agent said my 3320 was to big to be covered on my home owners policy.
We are with State Farm, they have house/cars/umbrella. I'll let everyone know how they behave.
Yeah, when I came down the driveway last night I said out loud "Golly gee, what in world happened to that shed? Oh holy moly, it looks like my nice green tractor is severely messed up".
Or words to that effect...
Pete
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A51244)
UNUSED FUTURE MINI...
