New Idea 517 value
/ New Idea 517 value #1
TheMadOne
Platinum Member
USA
Kubota L3560HSTC-LE, formerly L3301
How much should I offer for a 517 New Idea?
Also, will it pair well with a L3560?
/ New Idea 517 value #2
I guess it really depends on the condition- it looks like those were made in the 70's so i'd want to take a really good look at it, blowers are simple though. Supposedly they were well built - better than home owner grade, less than the pronovost, normand commercial grade.
as for pair it with a L3560,
Its a 2 auger 84" blower with i think a 26 inch fan so it could be done- probably better on the hydro trans (28 pto hp) than the gear (29.5 hp but i think it would be slow and would tax the tractor if you needed the twin auger (deep)- I am using 35 hp to drive a 74" single auger blower with a similar fan and it is below the recommended hp (40-70) but does a good job, i would however not want less power
I also imagine its pretty heavy.
/ New Idea 517 value #3
Here's a pic of my 516 - with single 84" auger. We use it on a 40 hp tractor that's enough power. But it would be a bit much for our 34 hp rig. 70995d1172369740-drag-blade-rear-mount-snowblower-snow-blower-manual-jpg.jpeg
/ New Idea 517 value #4
I think a 2-auger would be ok. We use a 516 (single auger) on a 40 hp tractor and there's enough power. I think I gave $250 for the blower. A 2-auger model would be a little heavier but would work fine. On a machine that has been unused for awhile, check there's oil in the gearbox. The fan on these can require a 20-ton pull to loosen from the shaft (ask me how I know:rolleyes:) The 516 got a drag blade and new paint added later. Still going great.
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
2001 Club Car Carryall 6 Medical Utility Cart (A64553)
2001 Club Car...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
2009 Kershaw 75-G2 Sky Trim (A65579)
2009 Kershaw 75-G2...
