New Idea 517 value
/ New Idea 517 value #1
TheMadOne
Platinum Member
USA
Kubota L3560HSTC-LE, formerly L3301
How much should I offer for a 517 New Idea?
Also, will it pair well with a L3560?
/ New Idea 517 value #2
I guess it really depends on the condition- it looks like those were made in the 70's so i'd want to take a really good look at it, blowers are simple though. Supposedly they were well built - better than home owner grade, less than the pronovost, normand commercial grade.
as for pair it with a L3560,
Its a 2 auger 84" blower with i think a 26 inch fan so it could be done- probably better on the hydro trans (28 pto hp) than the gear (29.5 hp but i think it would be slow and would tax the tractor if you needed the twin auger (deep)- I am using 35 hp to drive a 74" single auger blower with a similar fan and it is below the recommended hp (40-70) but does a good job, i would however not want less power
I also imagine its pretty heavy.
/ New Idea 517 value #3
Here's a pic of my 516 - with single 84" auger. We use it on a 40 hp tractor that's enough power. But it would be a bit much for our 34 hp rig. 70995d1172369740-drag-blade-rear-mount-snowblower-snow-blower-manual-jpg.jpeg
/ New Idea 517 value #4
I think a 2-auger would be ok. We use a 516 (single auger) on a 40 hp tractor and there's enough power. I think I gave $250 for the blower. A 2-auger model would be a little heavier but would work fine. On a machine that has been unused for awhile, check there's oil in the gearbox. The fan on these can require a 20-ton pull to loosen from the shaft (ask me how I know:rolleyes:) The 516 got a drag blade and new paint added later. Still going great.
2014 Kawasaki 70Z7 Articulated Wheel Loader (A64553)
2014 Kawasaki 70Z7...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2022 EZ-GO ELITE...
Wolverine SBM-12-72W Skid Steer Sickle Bar Mower  (A62679)
Wolverine...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
Kubota SVL 75-2 Skid Steer (A65579)
Kubota SVL 75-2...
