New house finally under way
   / New house finally under way
My well was ?$ for drilling plus casing per foot and a little less per drilled foot. Adding cost for pump and tank install.
Who did you use?
I hired Michael's Well out of Statham.
   / New house finally under way #62
For us guys that have never hired a deep well drill can someone educate us on the cost? Thanks.
Looks like I'll be up to $8 - $10k
   / New house finally under way #64
Our rural water district pumps out a deep aquafier. Withou a softner it's really hard on things.
Will your water be useable for household chores and/or drinkable?
Here's hoping he hits a good vein!!!
   / New house finally under way #65
Prime Pump and Well out of Dahlonega. It was in December of 2015 and was approximately $5K
   / New house finally under way #66
My water is fairly soft and very drinkable. 1000% better than SW Florida well water.
So not good news. Only 1.5 - 2gpm at 600'. Going to frack on Monday. Hopefully that'll double the output and we'll call it good enough.
I started looking at pumps as I may consider buying and installing myself to save a few bucks on that end.
   / New house finally under way #68
Think about how you are going to handle installing the pump and <600 feet of pipe before you decide to do the installation yourself. That plus the wire and miscellaneous items are going to add up to quite a bit of weight to handle without the proper equipment.
   / New house finally under way #69
Aw bummer. Here's hoping for more than that!!!! Gotta think optimistically!!!! Sorry for the hassles you are having.....
Pump will be in the 350' - 400' range. But you're point is still valid. Like I said, I'm looking into it so points like yours are certainly helpful.
Bale Spear - Fits John Deere 300/400/500 Series Carrier (A55301)
Bale Spear - Fits...
Giyi Mini Side Shift Forks (A53316)
Giyi Mini Side...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2022 Bobcat S770 Skidloader (RIDE AND DRIVE) (A50775)
2022 Bobcat S770...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
