New house finally under way
   / New house finally under way
My well was ?$ for drilling plus casing per foot and a little less per drilled foot. Adding cost for pump and tank install.
Who did you use?
I hired Michael's Well out of Statham.
   / New house finally under way #62
For us guys that have never hired a deep well drill can someone educate us on the cost? Thanks.
Looks like I'll be up to $8 - $10k
   / New house finally under way #64
Our rural water district pumps out a deep aquafier. Withou a softner it's really hard on things.
Will your water be useable for household chores and/or drinkable?
Here's hoping he hits a good vein!!!
   / New house finally under way #65
Prime Pump and Well out of Dahlonega. It was in December of 2015 and was approximately $5K
   / New house finally under way #66
My water is fairly soft and very drinkable. 1000% better than SW Florida well water.
So not good news. Only 1.5 - 2gpm at 600'. Going to frack on Monday. Hopefully that'll double the output and we'll call it good enough.
I started looking at pumps as I may consider buying and installing myself to save a few bucks on that end.
   / New house finally under way #68
Think about how you are going to handle installing the pump and <600 feet of pipe before you decide to do the installation yourself. That plus the wire and miscellaneous items are going to add up to quite a bit of weight to handle without the proper equipment.
   / New house finally under way #69
Aw bummer. Here's hoping for more than that!!!! Gotta think optimistically!!!! Sorry for the hassles you are having.....
Pump will be in the 350' - 400' range. But you're point is still valid. Like I said, I'm looking into it so points like yours are certainly helpful.
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
Kubota BX2230D (A47384)
Kubota BX2230D...
2022 Kubota U55-5 Midi Excavator (RIDE AND DRIVE) (A50775)
2022 Kubota U55-5...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
