mjncad
Super Member
Insulation and sealing the home will be the best passive energy saving investment you can make.
You need to contact a heating engineer called Doug Rye he is out of Arkansaw he has a web site and is an advocate of geo-thermal. I have had mine since 1990. It is the cheapest way I have to heat my house. I have hot water boiler and a wood stove but the geo is the most econimical there are more geo systems in Canada than the US and it has been around since the early 1900. Doug lists his phone # and will talk you thru what you need he will calclulate you furnace and a/c size if you send him your plans,
Do you have a big property ? Lot of acerage ? Acces to free burning wood ? If you don t mind the extra effort and have access to wood, this would be your cheapest long run option. A good design indoor gasifier wood boiler with appropriate storage usually need 1 fire a day. And you can heat the house wih radiant hydronic floor, and have your DHW heat by wood year round. But you have to remember that heating with wood is part of a lifestyle. If you hate processig wood, don t do it. There is a forum on wood burning with a LOT of usefuul info: hearth . com . I am in a new home and will be going with hydronic radiant that eventually will be heated by wood boiler
I have a wood boiler. I love it but it consumes a lot of wood.
I have a suggestion. I can't recall the name of what these are called - but basically its a masonry fireplace that takes long lengths of logs and it heats up a mass of block/stone which radiates heat long after the fire goes out. Burns very little wood.
Thanks for the replies. How often do you need to feed a wood boiler? Also, would anyone mind sharing their current utility setup, monthly cost and square footage of house for some comparison. Currently with electricity and natural gas my bill on the low end is $150 and high end is $300. My wife likes the house at 70 degrees year around. Square footage is 2400.
slowzuki said:Careful on the wood boiler, I wanted one originally when we built. My opinion changed mainly because most of them are terribly inefficient sometimes due to the boiler, sometimes the install. Some folks I know with them went from 3-5 cords per winter in woodstoves to 15+ cords in the OWB. Now they were burning proper dry hardwood in the stoves but like almost everyone they where burning not quite dry huge chunks in the boiler. To be fair with really dry wood it burned up fast so they had to be out there all the time.
It also smokes like the dickens in the fall and spring when it idles most of the time.
I'm a big fan of geothermal, there isn't anything fancy or modern about it, its technology from the 1800's called refrigeration. We all use it daily. There have been systems commonly installed locally since the late 60's early 70's. Still getting great COP's.
