New Holland Workmaster Rear Window Latch
   / New Holland Workmaster Rear Window Latch #1
Mike_in_Missouri
New Holland Workmaster 120 (decoration?), Massey Ferguson 135 (does all the hay work)
On my new Workmaster, noticed the rear window does not latch closed. Is there a known issue?
It'll latch to the cracked open position, but not closed. The tooth on the latch isn't long enough to properly seat in the latch mechanism below the window. Wondering if a space wasn't installed, etc...
   / New Holland Workmaster Rear Window Latch #2
Did you ever get this resolved what was the problem I have a new workmaster 75 with the same problem
   / New Holland Workmaster Rear Window Latch #3
Yes this is a know issue. Easiest fix is to shim the catch bracket up with a couple of washers
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
1111-A (A54756)
1111-A (A54756)
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
2012 Big Tex 25ft. 9 Ton T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 Big Tex 25ft...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
