New Holland Workmaster Rear Window Latch
   / New Holland Workmaster Rear Window Latch #1
Mike_in_Missouri
New Holland Workmaster 120 (decoration?), Massey Ferguson 135 (does all the hay work)
On my new Workmaster, noticed the rear window does not latch closed. Is there a known issue?
It'll latch to the cracked open position, but not closed. The tooth on the latch isn't long enough to properly seat in the latch mechanism below the window. Wondering if a space wasn't installed, etc...
   / New Holland Workmaster Rear Window Latch #2
Did you ever get this resolved what was the problem I have a new workmaster 75 with the same problem
   / New Holland Workmaster Rear Window Latch #3
Yes this is a know issue. Easiest fix is to shim the catch bracket up with a couple of washers
2025 transit van (A56858)
2025 transit van...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
KBH 25 TON TENDER (A56435)
KBH 25 TON TENDER...
2021 Deere 333G (A53317)
2021 Deere 333G...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
