New Holland Tractor - 6030.
   / New Holland Tractor - 6030. #1
farmboy90
Pratt, ks
new holland 6030
Hi - can anyone help? I have a New Holland 6030 tractor ,2011, that the fuel guage does not work. I have replaced the sending unit , replaced the guage cluster-assembly - and still doesnt work. I should have checked the wiring first - right? Now I have ohmed the two wires going from sender to cluster assembly and they are good - I can ground the voltage wire from the sender to the guage and it does not move- it should peg the guage. Any ideas out there? Thank you .
   / New Holland Tractor - 6030. #2
Welcome from Wisconsin,try grounding it to the frame of the tractor.
Yes.....I did try grounding the sender itself to the frame and didnt do any good. The sender has a sensor ground in the 2-wire plug.......and the tank is plastic....as I see it the only thing the metal wrong on top the sending unit does is hold it to the tank. Also, it should peg the guage if I paper-clip across the wire-plug to the sending unit? Thanks.
   / New Holland Tractor - 6030. #4
Welcome to TractorByNet!
I moved your thread to the New Holland Owning & Operating forum. :)
John Deere S780 Combine (A53342)
John Deere S780...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
