New Holland Tractor - 6030.
   / New Holland Tractor - 6030. #1
farmboy90
Pratt, ks
new holland 6030
Hi - can anyone help? I have a New Holland 6030 tractor ,2011, that the fuel guage does not work. I have replaced the sending unit , replaced the guage cluster-assembly - and still doesnt work. I should have checked the wiring first - right? Now I have ohmed the two wires going from sender to cluster assembly and they are good - I can ground the voltage wire from the sender to the guage and it does not move- it should peg the guage. Any ideas out there? Thank you .
   / New Holland Tractor - 6030. #2
Welcome from Wisconsin,try grounding it to the frame of the tractor.
Yes.....I did try grounding the sender itself to the frame and didnt do any good. The sender has a sensor ground in the 2-wire plug.......and the tank is plastic....as I see it the only thing the metal wrong on top the sending unit does is hold it to the tank. Also, it should peg the guage if I paper-clip across the wire-plug to the sending unit? Thanks.
   / New Holland Tractor - 6030. #4
Welcome to TractorByNet!
I moved your thread to the New Holland Owning & Operating forum. :)
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
John Deere 1025R (A53317)
John Deere 1025R...
2005 Chevrolet Silverado Pickup Truck, VIN # 1GCHK232X5F955091 (A57453)
2005 Chevrolet...
2017 Genie GTH-5519 (A53317)
2017 Genie...
MILWAUKEE & DEWALT SAWZALL (A58374)
MILWAUKEE & DEWALT...
2014 Toro Z-Master 5000 Series 72in Zero-Turn Commercial Mower (A56857)
2014 Toro Z-Master...
