New Holland Tractor - 6030.
   / New Holland Tractor - 6030. #1
farmboy90
Pratt, ks
new holland 6030
Hi - can anyone help? I have a New Holland 6030 tractor ,2011, that the fuel guage does not work. I have replaced the sending unit , replaced the guage cluster-assembly - and still doesnt work. I should have checked the wiring first - right? Now I have ohmed the two wires going from sender to cluster assembly and they are good - I can ground the voltage wire from the sender to the guage and it does not move- it should peg the guage. Any ideas out there? Thank you .
   / New Holland Tractor - 6030. #2
Welcome from Wisconsin,try grounding it to the frame of the tractor.
Yes.....I did try grounding the sender itself to the frame and didnt do any good. The sender has a sensor ground in the 2-wire plug.......and the tank is plastic....as I see it the only thing the metal wrong on top the sending unit does is hold it to the tank. Also, it should peg the guage if I paper-clip across the wire-plug to the sending unit? Thanks.
   / New Holland Tractor - 6030. #4
Welcome to TractorByNet!
I moved your thread to the New Holland Owning & Operating forum. :)
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
100 GAL FUEL TANK W/ PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
John Deere 6120E (A50323)
John Deere 6120E...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
