New Holland TC45DA tilt steering broken
   / New Holland TC45DA tilt steering broken #11
"RR" usually means "Remove & Replace" and that is how I read the comment.
Is often hard to "see" a blown fuse. A meter is a much better tool for verifying.
   / New Holland TC45DA tilt steering broken #12
Ignition switch???
   / New Holland TC45DA tilt steering broken #13
Sounds like a wire may have come off the ignition switch or broke a wire there while the right panel was off.
   / New Holland TC45DA tilt steering broken #14
Did you check the simple stuff first? Usually when I work on mine, I always leave it partially in gear or the cruise control in engaged ,pto on, by leaning on the levers or just fiddling around. 🍻
   / New Holland TC45DA tilt steering broken #15
Sorry for the confusion when you "Remove and Replaced" the panel may have caused a short and blew a fuse.
   / New Holland TC45DA tilt steering broken #16
I recommend you test your fuses with a multimeter, I have had fuses pass visual inspection, but fail multimeter. Very frustrating.
2013 30' Flatbed Trailer (A57148)
2013 30' Flatbed...
Skid Steer 66in Skeleton Bucket (New/Unused) (A59225)
Skid Steer 66in...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
2019 PETERBUILT 579  DAYCAB (A58214)
2019 PETERBUILT...
