New Holland TC45DA tilt steering broken
   / New Holland TC45DA tilt steering broken #11
"RR" usually means "Remove & Replace" and that is how I read the comment.
Is often hard to "see" a blown fuse. A meter is a much better tool for verifying.
   / New Holland TC45DA tilt steering broken #12
Ignition switch???
   / New Holland TC45DA tilt steering broken #13
Sounds like a wire may have come off the ignition switch or broke a wire there while the right panel was off.
   / New Holland TC45DA tilt steering broken #14
Did you check the simple stuff first? Usually when I work on mine, I always leave it partially in gear or the cruise control in engaged ,pto on, by leaning on the levers or just fiddling around. 🍻
   / New Holland TC45DA tilt steering broken #15
Sorry for the confusion when you "Remove and Replaced" the panel may have caused a short and blew a fuse.
   / New Holland TC45DA tilt steering broken #16
I recommend you test your fuses with a multimeter, I have had fuses pass visual inspection, but fail multimeter. Very frustrating.
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
light tower (A56857)
