New Holland TC45DA tilt steering broken
   / New Holland TC45DA tilt steering broken #11
"RR" usually means "Remove & Replace" and that is how I read the comment.
Is often hard to "see" a blown fuse. A meter is a much better tool for verifying.
   / New Holland TC45DA tilt steering broken #12
Ignition switch???
   / New Holland TC45DA tilt steering broken #13
Sounds like a wire may have come off the ignition switch or broke a wire there while the right panel was off.
   / New Holland TC45DA tilt steering broken #14
Did you check the simple stuff first? Usually when I work on mine, I always leave it partially in gear or the cruise control in engaged ,pto on, by leaning on the levers or just fiddling around. 🍻
   / New Holland TC45DA tilt steering broken #15
Sorry for the confusion when you "Remove and Replaced" the panel may have caused a short and blew a fuse.
   / New Holland TC45DA tilt steering broken #16
I recommend you test your fuses with a multimeter, I have had fuses pass visual inspection, but fail multimeter. Very frustrating.
2019 F150 (A56435)
2019 F150 (A56435)
2005 John Deere 330CL (A55272)
2005 John Deere...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTVFX1E84NFB46867, Crew Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
Massey Ferguson 1759 (A57148)
Massey Ferguson...
8065 (A55852)
8065 (A55852)
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
