New Holland/Ford 3910- How do you turn it off
   / New Holland/Ford 3910- How do you turn it off #1
MESSMAKER
Bluegrass,KY
DK4710SE
Key turns on tractor and operates dash lights but does not turn it off. Does it have a kill switch?
   / New Holland/Ford 3910- How do you turn it off #2
I used to have a 3910... it shut down with a fuel shut off. There was a knob below the ignition key. If that's not there, you might have to find the shut off on the injector pump.
   / New Holland/Ford 3910- How do you turn it off #3
If it doesn't have a manual shut off it probably has an electric. Our 3930 has an electric which doesn't work. I just shut it off by manually by hand
   / New Holland/Ford 3910- How do you turn it off #4
Is this something that just happened or has it always been this way or is it new to you. you should have a cable or rod that goes to injection pump if its a manual or an electric solenoid on the pump will usually have a couple of wire going to it if this is the case try unplugging this with it running to see if it shuts down
I am guessing it has a fuel shut off and I missed it. I was in a dark barn when I was trying to figure it out.
   / New Holland/Ford 3910- How do you turn it off #6
Look for a red knob that pulls out to shut off fuel. Lower right side of dash.
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
Case 821F Articulated Wheel Loader (A51691)
Case 821F...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
Canal Pump (A50121)
Canal Pump (A50121)
