New Holland/Ford 3910- How do you turn it off
   / New Holland/Ford 3910- How do you turn it off #1
MESSMAKER
Bluegrass,KY
DK4710SE
Key turns on tractor and operates dash lights but does not turn it off. Does it have a kill switch?
   / New Holland/Ford 3910- How do you turn it off #2
I used to have a 3910... it shut down with a fuel shut off. There was a knob below the ignition key. If that's not there, you might have to find the shut off on the injector pump.
   / New Holland/Ford 3910- How do you turn it off #3
If it doesn't have a manual shut off it probably has an electric. Our 3930 has an electric which doesn't work. I just shut it off by manually by hand
   / New Holland/Ford 3910- How do you turn it off #4
Is this something that just happened or has it always been this way or is it new to you. you should have a cable or rod that goes to injection pump if its a manual or an electric solenoid on the pump will usually have a couple of wire going to it if this is the case try unplugging this with it running to see if it shuts down
I am guessing it has a fuel shut off and I missed it. I was in a dark barn when I was trying to figure it out.
   / New Holland/Ford 3910- How do you turn it off #6
Look for a red knob that pulls out to shut off fuel. Lower right side of dash.
PITTSBURG 2R CULTIVATOR W/ ALL FEET (A52708)
PITTSBURG 2R...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2015 Peterbilt 320 Garbage Truck (A55973)
2015 Peterbilt 320...
2020 DRAGON ESP...
