New Holland/Ford 3910- How do you turn it off
   / New Holland/Ford 3910- How do you turn it off #1
MESSMAKER
Bluegrass,KY
DK4710SE
Key turns on tractor and operates dash lights but does not turn it off. Does it have a kill switch?
   / New Holland/Ford 3910- How do you turn it off #2
I used to have a 3910... it shut down with a fuel shut off. There was a knob below the ignition key. If that's not there, you might have to find the shut off on the injector pump.
   / New Holland/Ford 3910- How do you turn it off #3
If it doesn't have a manual shut off it probably has an electric. Our 3930 has an electric which doesn't work. I just shut it off by manually by hand
   / New Holland/Ford 3910- How do you turn it off #4
Is this something that just happened or has it always been this way or is it new to you. you should have a cable or rod that goes to injection pump if its a manual or an electric solenoid on the pump will usually have a couple of wire going to it if this is the case try unplugging this with it running to see if it shuts down
I am guessing it has a fuel shut off and I missed it. I was in a dark barn when I was trying to figure it out.
   / New Holland/Ford 3910- How do you turn it off #6
Look for a red knob that pulls out to shut off fuel. Lower right side of dash.
2014 RAM 4500 versa LIFT bucket truck (A52377)
2014 RAM 4500...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
72" Hydraulic Broom  (A52384)
72" Hydraulic...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
