Traction New Holland 1720 front wheels won't turn
   / New Holland 1720 front wheels won't turn #1
Meltd0wn
Bethany, NY
New Holland 1720 and a Massey Ferguson 275
I was using a 3 point hitch mower deck on the lawn in 4-wheel drive. Parts of the lawn are steep which is why I needed the extra traction. I heard a popping noise and suddenly the front wheels were being pushed along by the rear wheels. I lifted the front wheels off of the ground with the front loader and found that they will spin in opposite directions, just not in the same direction at the same time. Any ideas?
   / New Holland 1720 front wheels won't turn #2
Any regular differential will behave that way. Did you try with 4wd disengaged? In that case the driveshaft might spin instead of the other wheel.
Not sure what you meant "pushing the front end around". Like no drive to front tires?
Jom
Jom
Front wheels won't spin in the same direction at the same time, forwards or reverse. It doesn't matter if it's in 4 WD or 2 WD, the results are the same. I'm removing the drives haft to see if the front end is locked or if something happened in the transfer case. Thanks for the reply. I will post the results of removing the drive shaft.
:drink:
   / New Holland 1720 front wheels won't turn #4
Did it do this on the ground? If so...something before the axles is the problem. Driveshaft, differential carrier, etc is locked up. Im wondering if something got wedged between the ring and pinion
   / New Holland 1720 front wheels won't turn #5
I run my 1720 in 4 wheel assist while I mow also...
Just keep in mind that even with the front axle engaged you still only have 1 rear and 1 front tire pulling...
It is not a true 4 wheel drive since the front axles don't pull both front tires...
Okay, let me see if I can explain this better. While going forwards or backwards, the front wheels won't turn. The front wheels just push furrows into the ground. I removed the drive shaft (after a lot of cussing) and found that the transfer shaft spins free. The pinion shaft in the front axle is locked tighter than a bug's pooper in January. There's something very wrong in the front differential. With the front end off of the ground, however, if one tire is spun, the other tire spins in the opposite direction as expected. It's obviously the pinion shaft that's stuck...I'm thinking the pinion bearing. :thumbsup:
I think I'm confusing y'all by saying "turn" instead of "spin" :banghead:
   / New Holland 1720 front wheels won't turn #9
It could also be a carrier bearing. Hopefully its cheap and fairly easy once you get in there......
2010 Chrysler Town and Country Touring Van (A50324)
2010 Chrysler Town...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
