Traction New Holland 1720 front wheels won't turn
   / New Holland 1720 front wheels won't turn #1
Meltd0wn
Bethany, NY
New Holland 1720 and a Massey Ferguson 275
I was using a 3 point hitch mower deck on the lawn in 4-wheel drive. Parts of the lawn are steep which is why I needed the extra traction. I heard a popping noise and suddenly the front wheels were being pushed along by the rear wheels. I lifted the front wheels off of the ground with the front loader and found that they will spin in opposite directions, just not in the same direction at the same time. Any ideas?
   / New Holland 1720 front wheels won't turn #2
Any regular differential will behave that way. Did you try with 4wd disengaged? In that case the driveshaft might spin instead of the other wheel.
Not sure what you meant "pushing the front end around". Like no drive to front tires?
Jom
Jom
Front wheels won't spin in the same direction at the same time, forwards or reverse. It doesn't matter if it's in 4 WD or 2 WD, the results are the same. I'm removing the drives haft to see if the front end is locked or if something happened in the transfer case. Thanks for the reply. I will post the results of removing the drive shaft.
:drink:
   / New Holland 1720 front wheels won't turn #4
Did it do this on the ground? If so...something before the axles is the problem. Driveshaft, differential carrier, etc is locked up. Im wondering if something got wedged between the ring and pinion
   / New Holland 1720 front wheels won't turn #5
I run my 1720 in 4 wheel assist while I mow also...
Just keep in mind that even with the front axle engaged you still only have 1 rear and 1 front tire pulling...
It is not a true 4 wheel drive since the front axles don't pull both front tires...
Okay, let me see if I can explain this better. While going forwards or backwards, the front wheels won't turn. The front wheels just push furrows into the ground. I removed the drive shaft (after a lot of cussing) and found that the transfer shaft spins free. The pinion shaft in the front axle is locked tighter than a bug's pooper in January. There's something very wrong in the front differential. With the front end off of the ground, however, if one tire is spun, the other tire spins in the opposite direction as expected. It's obviously the pinion shaft that's stuck...I'm thinking the pinion bearing. :thumbsup:
I think I'm confusing y'all by saying "turn" instead of "spin" :banghead:
   / New Holland 1720 front wheels won't turn #9
It could also be a carrier bearing. Hopefully its cheap and fairly easy once you get in there......
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A52748)
2023 NEW HOLLAND...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
