New haying equipment
/ New haying equipment #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
I just purchased some new haying equipment and thought I would share some pictures with everyone. The first one is a brand new RR2109 rotary rake and the second one (no pics yet still waiting delivery) a new to me 568 round baler. Hopefully if the weather holds up I will be raking Tuesday or Thursday and baling Saturday or Sunday.
The manual for the rotary rake says to not operate in the raised position, what would happen if I raised it while it's running (say to end one row and lift it and turn to make a new row so I don't rake up rows I don't want to rake.)
/ New haying equipment #2
Nice equipment. Congratulations. I don't think that raising it for such a short period of time, would cause any problems.
Thank you, I got lucky to get the rake, it was the last one on the lot and while I was doing the paperwork another guy came in looking at a rake too. I felt bad for him but glad I grabbed it when I did.
That's what I thought too but still not sure what problems it could cause, the angle isn't even that big.
/ New haying equipment #4
nice equipment, my neighbor who does my hay has a 568 baler and man has that thing baled a lot of hay with very little problem. good luck haying
Thank you, that's good to know cause this one has 10,000 bales on it already but looks really good and the dealer is very supportive of it being sound and solid. Thanks, a little nervous being my first time with a) this equipment b) doing someone else's hay c) this is my first year and not sure on really when to do things or know when to move onto the next step. The weather forecast has been so unreliable this year that I just don't know what to do, one day it says no rain for a week so I start getting equipment ready then the next day it's 40% chance of 1mm of rain almost everyday, then when the day gets here it doesn't rain or if it does it rains for 30 min and 5 min later it's all dry like it never rained (very fustrated.)
/ New haying equipment #6
Very nice rake, Corey. I've got an older, Kuhn rotary rake (I think Kuhn makes a lot of the Deere hay implements) that is a great piece of equipment! Don't think that's it's a real big deal to raise the rake up a bit... just watch the angle of your PTO shaft.
That said, with the electronic PTO (and ePTO) is just a simple "snap" and it's on and off. No grinding, no pause -- it's ON-OFF. I generally stop the pto at the end of the row and maneuver and snap it on again when I'm ready for the next windrow. That way I don't have to worry about the shaft or revolving tines snagging something and causing a problem.
Got our hay done last week. Great quality hay... good color and high leaf content and 8-9% moisture! But.... the tonnage was down by 1/2! :mad: Couple of fields that have yielded 3 tons/acre in the past only produced 1.5 ton/acre!
Very dry up here this season with a lot of sunny days! Tourists are loving it but it's not good for hay farmers...
AKfish
AKfish
Do you idle down when you turn it back on? I use 540e and have the tractor at high idle (1200rpm) when operating the rake if I re-engage the PTO I get a lot of grinding noise at low idle or high idle before it is fully spun up.
Baler showed up, it makes the tractor look small. I hope it won't be too high to cause me to roll on a hill side. One slope makes me grab the instructor seat for balance.
/ New haying equipment #9
It's hard to believe a baler that pretty has baled 10,000 bales. Good luck.
/ New haying equipment #12
I don't make hay, but when I'm rototilling or spreading manure. I usually do not idle down. I think it uses more fuel by idling down to 850RPM then revving right back up quickly.
That's what I thought too but what about the effects it has on the PTO shaft and gear box?
/ New haying equipment #14
i sure hope your dealer went completely trough that baler an fixxed any probs an got it field ready.because if he didnt it could eat your lunch with alot of unknown probs.i know because we bought a like new 2006 567 with 2600 bales on it.an the guy said it was field ready wrong.we had JD pick it up after found 2 blown bearing in it.an had them go completely through it.well it had alot wrong with it an they got it running.the only thing we had todo is have them rebuild the hydro cylinders on the tail gate wich they didnt do in the shop.
/ New haying equipment #15
Heck - might be better because it has been run. Maintenance and what has been run thru it makes a huge difference.
I lost both tension cylinders last year on my 467. Not a big deal to fix, but a pain on a holiday weekend.
D.
/ New haying equipment #16
i hope your right.the baler we bought sat in the hay barn for 3 or 4yrs without being ran.then the guy at the JD house that went through it offered to buy it off of us lolol.but hey we stole the baler,gave well under $20,000 for it.
Yes he went through it all and checked everything over, he will be with me all morning to make sure I know how to properly use it and that it's properly working. If anything goes wrong he will fix it free. He promised it will be in a field ready state upon delivery and is making sure I will go back to him when I upgrade my equipment. I hope everything goes good, he said the bearings were in good shape when he looked it over. I just hope if something does happen he will back up what he said.
D.
That's what I was thinking, it's done it's break in period and the previous owner had two of them that always worked in tandem, you can see that he took care of it cause you can see where grease splattered on shields and covers from lots of greasing. He trades all his balers in after the end of the season he reaches 10,000 bales.
The dealer hooked this one up and ran it at the dealership to make sure everything was running perfectly so I'm hoping if something wasn't right his mechanics would have noticed it, if not then I'm relying on my "new" dealers word.
/ New haying equipment #18
Congrats, that is good looking equipment. One question, you mentioned going across hills, why not space your rear tires wider to give you better stability?
Thank you. I've thought about that cause it is on the second narrowest stance but I don't have tools big enough to do it and the cost to have them come out to do it is brutally high cause of the distance to travel and my tires being loaded.
Talk about service, today after he gets off work my dealer comes out to see how everything is going and give me a brand new spare tire for the baler and manual, asked me if I had any questions about any of my equipment and might be getting me into a slightly used 6R. He will be back on Friday and will spend the morning making sure everything works perfectly when I bale.
