JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,032
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
The 1260 seems to be working ok so far. It's not really thick brush, more like tall grasses and bushes.
I'd be interested to know what the differences are between the two. My dealer even came out to the property before I purchased to see if the equipment I was looking at was up to the task....
Nice machine. I'm sure up there in the colder climes you will make good use of that cab. I have an older Kubota roughly the size of yours (B2150) with FEL, 4' hog and 5ft snowblower. I had the same turf tires you show but converted to AG tires and it works so much better in snow. I suspect in snow you will need chains or else get hung up a lot in deeper snow or wet snow. If you are there all the time, and able to keep the snow from building up to more depth, you'll be fine. That RCR1260 should be just about ideal for cutting light brush and tall grass. The more you cut it the easier it gets AND the cleaner the result. I use a 4' hog in a place I can only cut once a month and it works great. Key is keep it sharp.
) so hopefully the turfs will do fine. The dealer told me his customers do best for snowblowing with the turfs, and being a total newbie, I didn't really have much to add.
