New Guy
/ New Guy #11
The 1260 seems to be working ok so far. It's not really thick brush, more like tall grasses and bushes.
I'd be interested to know what the differences are between the two. My dealer even came out to the property before I purchased to see if the equipment I was looking at was up to the task....
Nice machine. I'm sure up there in the colder climes you will make good use of that cab. I have an older Kubota roughly the size of yours (B2150) with FEL, 4' hog and 5ft snowblower. I had the same turf tires you show but converted to AG tires and it works so much better in snow. I suspect in snow you will need chains or else get hung up a lot in deeper snow or wet snow. If you are there all the time, and able to keep the snow from building up to more depth, you'll be fine. That RCR1260 should be just about ideal for cutting light brush and tall grass. The more you cut it the easier it gets AND the cleaner the result. I use a 4' hog in a place I can only cut once a month and it works great. Key is keep it sharp.
/ New Guy
Thanks for that! I'm going to be here all the time (retiring ) so hopefully the turfs will do fine. The dealer told me his customers do best for snowblowing with the turfs, and being a total newbie, I didn't really have much to add.
I'll definitely keep your advice in mind, really hoping that keeping that neglected area well cut now will make it a lot nicer. I've already noticed that it is growing back in with what looks to be a nice grass.
In your experience, did you find that over time, all that mulch of cut weeds/grass etc settled in? The second time I cut, seemed to break that stuff up even More, but brought it all to the surface again.
/ New Guy #13
The big difference is that the 1260 is rated for 1" material and the 1860 is rated at 2". Also the 1860 has a slip clutch instead of a sheer bolt and the 1860 has a more rugged gearbox with a 5 year warranty instead of 3 years.
But if all you are doing is cutting grass, then it should be more than enough.
/ New Guy #14
Yes, the mulch of grass and debris settles in so much I can barely tell it is there BUT that's because I am only able to be there to cut it once a month. And I have cut it so many times that the mulch is fairly fine grass. Back to the snowblowing/removal: the problem with turf tires is that the very slightest spin immediately causes ice under the wheels and makes it very difficult to work from there on. The AG tire cleats dig down in and provide traction. Surprising how easy it is to get hung up even with 4WD in deeper snow. But like I said, if you are there all the time and do not let the snow get too deep (especially wet snow) then you will be fine. My problem is not being there for long periods.
/ New Guy
^ Thanks JWR, I really appreciate the input!
I'm thinking I'll see how it goes this winter. My dealer said he'd swap the tires out for me if I had any problems, and he loaded the turfs for me too.
Thank you again for the help! Cheers!
/ New Guy
Thanks for letting me know, I was just curious. Sounds like I'll probably be ok with the 1260 for now.
Cheers for the info!
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
2012 Ford F-250V Ext-Cab Pickup Truck (A59230)
2012 Ford F-250V...
