Tiller New guy need help with JD 445 tiller
   / New guy need help with JD 445 tiller #1
cottermac
John Deere 1026R
I was wondering if anybody out there has takin a new 42 inch hydraulic tiller from a x585 or x700 and mounted it to a 445? I ordered 3pt and the dealer said that the newer tillers won't fit the older tractors. I have been looking for pics of the newer hydraulic tillers mounting bracket with no success. I'm hoping I'm not the first person with this idea. I'm open to suggestions and would be grateful for some help.
   / New guy need help with JD 445 tiller #2
:welcome:
Did the dealer give any specifics as to what you might have to change?
The differences on my 445 to the X485 were that the old attachments would work on the newer model, but the new attachments would not work on the older model.
Thank you
No they didn't give me any specs, thats why I was try to find some pics. I was thinking if the attachment would go from old to new, then they should go both ways.
   / New guy need help with JD 445 tiller #4
Be nice, but then things would never change.
Any chance to find a model tiller that fits the 445?
Does the new hydraulic tiller have the mid PTO hyd pump?
I see that it does, so that is the main difference. The frame of the newer tractors (X585) is different from the 445, and requires a different drive shaft/pump motor combination. If you can find/buy the 445 pump and drive shaft (with mounting), then the tiller looks to be the same (but didn't look at the 3 ph to see if they were the same or different).
Found this information on jdparts. You can register there (free) and look up the parts between the different tractors that take the 42 inch hyd. tiller.
Yes, that's what I'm tryn to figure out what it looks like so I can see if it will mount up to the 445.
Thank you that's what I was looking for.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
set of 4 tractor trailer tires Roadforce (A56436)
set of 4 tractor...
More info coming soon! (A56858)
More info coming...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2009 Cadillac CTS Sedan (A59231)
2009 Cadillac CTS...
