New gearbox for SQ720?
/ New gearbox for SQ720? #1
Northern, MN
JD 4600
Well, after almost 20 years of faithful service, the output shaft on my SQ720 sheered when I hit a small stump.
Is there any economical replacements available, other than the $600 OEM replacement?
The blades have also worn the steel through on the stump jumper around the blade bolts. So maybe it's time to put it out to pasture? The mowerdeck itself is still in quite good condition for it's age.
/ New gearbox for SQ720? #2
Do you know what the gear ratio is on your existing gear box? Have you tried searching by the OEM part number to see if any substitutes pop up? I believe the majority of gear boxes manufactured over seas so not sure how the quality compares from brand A to brand B.
/ New gearbox for SQ720? #3
Is there an ID tag or numbers on the gearbox? If there is, chances are Google can get a parts breakdown, and then a part number. Might have to work backwards from the tag on the deck. For the wallowed out holes, weld a large washer over the area to bring it back to spec.
/ New gearbox for SQ720? #4
You should be able to get a replacement shaft, and a replacement weld on pan if you choose. Should be a number or I.D tag on the gearbox , once you know the gear box info you can find a replacement that matches as stated above.
/ New gearbox for SQ720? #7
Agri Supply has a number of gearboxes, with specs such as bolt center, gear ratios, HP rating, shaft size/style listed. Also sell pans.
/ New gearbox for SQ720? #8
This site has gear boxes near last pages of catalog...
Surplus Center
DO NOT know anything about company, but have seen it mentioned several times in several threads...
Dale
I have ordered from Surplus Center for over 25 years with good service and fast shipping AND they are a sponsor here.
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
Case Titan 3530 (A63688)
Case Titan 3530...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
