New garage time!
/ New garage time!
Got some benches made, separated into 2 banks, and got the top balance chargers on.
/ New garage time!
Talk about busy work. I'm debating hooking one up to the inverter and charging from that to 80%, then breaking it down again and top balancing from there.
I guess I can't configure the bms from the inverter even with coms. I guess my next adventure is in figuring out how to configure bms's.
/ New garage time!
I got lucky. I ran ethernet from the bms port on the inverter, and hooked up a pack with bms, and boom. first protocol worked. Now the inverter knows the voltage.
Problem is I don't know how to tell the bms how big it's pack size is. It does not have bluetooth.
/ New garage time! #1,484
So, not exactly plug and play?
/ New garage time! #1,485
/ New garage time!
So I'm at 97% battery and charging has slowed considerably. I set it to 55.5v for back2ac. The charger basically topped out at 56.1v for the battery. There is a 0.5v drop between the battery and the inverter.
All settings are on the inverter, nothing with SA automation.
It should have switched back by now. But it hasn't.
/ New garage time!
As I hit submit, I heard a beep indicating that it was switching priority. Battery is a go!
/ New garage time!
Now with battery hooked up I can see what the panels are actually pushing out. Looks like 3600w of panels at 18 degrees on the winter solstice where 44 degrees is optimal can do 2500w. It's currently 21f, which is probably helping some.
This is 15x panels where I have 45x to put up, so I should be able to get 7500w out of it next winter during the shortest day.
/ New garage time!
Just finished top balancing pack 3, hooked everything up and all the cells are dead on, except cell 1, which is a bit lower. I'm wondering if it's the draw of powering the bms that's lowering that specific cell. I don't recall this happening on the previous packs.
/ New garage time!
So I went to the pack and checked it with multimeter and it is checking at 3.63v, so something is wrong with the bms or crimped end or ring terminal that's creating resistance. I'm going to take it off and redo it.
/ New garage time!
3 packs totaling 45kwh are in opperation, and the 4th pack is built and just about ready to start charging.
I have space for 2 more packs at the top, but I'm going to see how this does me for now. Once it's done, I'll start working on getting the other inverters online.
/ New garage time!
Now that 3 batteries are online, and a 4th top balancing, I can take some time to get more inverters hooked up. Got 2 more inverters nearly done. Cables run, ends crimped, heat shrink on. It almost looks professional.
I hate how the negative lug is behind the pv wires though.
/ New garage time!
Aww yes...
So I can't quite figure out how to get SA to change the order of inverters, or be able to label them. It does what it wants. But I can infer which ones are which by looking at load.
Everything is online, split phase, cables wired properly, current sharing, 18kw total, 9k per leg.
Tomorrow, more battery work.
/ New garage time!
Well I cranked out 14.5kwh today from 15 panels, and there were some dips.
I have 24 panels up in a 6x4 grid, but I'm running 15 panels per inverter. Which means I had 9 up and doing nothing.
So I decided to put one more up, and wire them up in a 5s2p instead of 5s3p.
This is a very temporary setup. I rigged it in a way that it would not interfere with me putting up the rest of the racking for the second set of 24 panels. I need to drop the back end by about an inch.
All I am missing is some bus bars so I couldn't wire them into the combiner box. I'll pick them up tomorrow then hook up some wires and I'll increase my generation by 66%.
/ New garage time!
I filed plans with the township to get approval and the zoning was approved, but the one guy is looking for a structural engineer signoff. I called 3 SE's and none will touch anything they didn't design themselves. Which is really irritating.
/ New garage time! #1,497
Could be a challenge. Best of luck.
/ New garage time! #1,498
Is this for the solar array structure, or for the barn/shop/garage? Or both?
/ New garage time!
The solar array structure over my patio since it's a "roof" for my patio.
/ New garage time!
TSC chicks are $6.99 and $9.99 for premium. Still no chicks at TSC.
As such, i've decided to breed what I have.
I'm building a new coop at the other end of the run, and I'm going to isolate my rooster, 6 egger hens, and 4 RiR's. Once isolated they'll spend 2 weeks together then I'll assume the eggs are fertilized. I'll start setting them aside then.
I have a 30 egg incubator that was a nightmare to find. But it's done.
Word has gotten out, people are asking me for fertilized eggs.
So here I have my new coop. Some assembly required.
New coop will double as brooder once the chicks hatch, so that'll be nice.
Mahindra Mforce 105p (A64126)
Mahindra Mforce...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
(3) STIHL POLE SAWS (A64276)
(3) STIHL POLE...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
