New garage time!
/ New garage time! #961
I have went, in the past, as far as throwing a rope over the top and pulling a ladder up to lay on the roof. Tie off the rope and ladder and work from ladder and move it over as I go. Slow but safer. I have some 6/12 and 7/12 sections, but the porch is 4/12. All shingled.
/ New garage time! #962
Most of my house is 10/12. I have roof jacks I used when shingling. Some is 4/12, that’s nothing with shingles. But last time I had hail damage Insurance paid for others to replace it all.
/ New garage time!
Ice and water shield on. Cleaned up the second floor a bit and put the lights up. Had a tricky time getting the wires up over a big gaping hole, but I found something that worked.
Tomorrow, going to cut and install the lateral bracing between the studs, and do a good bit of cleanup. Need to pick up the man doors and get them in. Garage door guy came today, $2900 installed for both, lead time 3 weeks.
Metal roof quote came in, $5500 for roof and all the trim. 7-10 day lead time. We should be finished by december.
/ New garage time! #964
I looked at buying a house with a metal roof once and noticed it had tie off points all over it. I made a note to myself to never install a metal roof in our wet marine climate. I do have a metal roof on my shop (there when I bought it) but it is a slight slope and I took trees down around it to limit the debris needing to be cleaned off.
/ New garage time!
More fence. This time with the 8" auger and the 21" extension. That thing kicked the crap out of me. I actually had to take a break half way through the hole because my hands were cramping up from trying to hold onto it.
Going to wait on the gate until I get the roof and siding so I don't have to do any disassembling. I'm going to ask them to crane the roof up onto the roof, it'll make life a lot easier.
/ New garage time! #966
Looks great, but dude that is a Monolith. IF you start seeing monkeys playing with leg bones,. make a run for it.....; ).
/ New garage time! #968
And to think he ran his fence right up to his neighbor's building and built his monolith while the neighbor was gone north for the summer!!!!! :laughing: Jon
/ New garage time!
Tyvek started, first row was not bad. Second is a challenge. 3rd I'm not sure I want to think about yet.
Made a tyvek on a stick using a foot from scaffolding bolted to a 2x6. It's fairly unstable but it gets the job done.
/ New garage time! #970
It's such a mundane task. And such an important task. Your pics show you the value of Tyvek. Hang in there. Do it right.
/ New garage time! #971
I had to hang Tyvek by myself on a 12 foot wall. I didn't want to move the scaffold every time so I ran the Tyvek up and down instead and taped the joints. It meant that I could completely finish a 10 foot section of wall, tar paper, Tyvek, siding and soffit, and then move the scaffold. As I was working by myself this saved me a lot of time and effort.
/ New garage time!
It was actually really easy after the sun set, we could see the studs through the gaps so we knew where to nail.
/ New garage time! #973
On my 2nd flooring, dropped ropes from the soffits, attach tyvek to long 2x4, and pull it up like a curtain. Once pulled up, climbed ladder to staple it on. At top, reached over wall top to fasten.
/ New garage time!
On the last section on the back wall I came up with this ingenius idea. It saved so much time vs ladders and pump jacks, and we could have used it for the second floor as well. Kicking myself a bit but lesson learned.
10' section of all-thread, plate and bolt at the bottom, board on top. One on the roof sliding it along, and holding the top, another hanging over stapling the top. Then went back with the 24' aluminum ladder and went around and stapled the bottom. No need to hold a heavy long roll of tyvek. And I adjusted the bolt so it would line up perfectly with where we needed it.
/ New garage time! #975
Great solution 🤙
/ New garage time!
Got the doors installed. Miserable weather and it's going to get worse so just in time i guess. Garage doors are 2 weeks out yet. Can't wait to get them installed. I need to do some organizing, stuff is laying everywhere.
Decided to do the siding first, then the roof, so we're not up on a metal roof trying to put siding up.
/ New garage time! #978
Wall Tyvek will last all Winter without additional covering.
Will your current roof material last all Winter without additional covering?
/ New garage time!
Metal roof, all the trim and soffits, and siding have been ordered. I’m not stopping for the winter.
/ New garage time! #980
Oh, I didn't realize you don't even have the roof material yet. I thought by your post that you "chose" to do the walls first.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
UNUSED X-STAR 300 GALLON FUEL TRAILOR (A64280)
UNUSED X-STAR 300...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
2025 Kivel 48in Fork and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
