New garage time!
/ New garage time!
12ft sounds smart for drywalling efficiency assuming that is your plan.
More so for auto lift. The bottom 2' of block is 2' so it wouldn't be full sheets anyway. I just wanted large unobstructed space. I have a lot of big machines, as well as vehicles. I want to be able to easily work on them in the comfort of indoors.
/ New garage time! #442
I'd be tempted to keep the bottom of the drywall at the bottom of the wood framing. The bottom 2' of wall is likely to get banged up and or wet.
/ New garage time! #443
A trick that I use when standing up heavy walls is to only install every 3rd or 4th stud. Then after I get the wall up, I go back and install the rest of the studs. It's a little slower that way, but there is a massive difference in how heavy the wall is when lifting it. Especially if you are working alone.
/ New garage time! #444
Good tip!
/ New garage time! #445
Last time I stood up walls I cheated - used FEL.
/ New garage time! #446
just thinking about standing up a 2x8"x10' studded wall makes my back ache. That garage is going to be stout!
/ New garage time! #447
All two post auto lifts that I have helped install were 12' tall. Not 11'11". 12'. Really need 12'2'' to stand them up easily. Hope you are allowing for your ceiling material thickness in your equation.
We forgot that tidbit in my Son's shop. Had to use a shop mall to beat the lift into place. You can't see that it raised the ceiling 5/8" but it did.
/ New garage time!
Made a bit more progress today. Got some info on the flooring as well. Clark Dietrich TradeReady™ Steel Joists, 16" on center gives me 25psf dead load, 40psf live load, spanning the width of the garage. It looks like I'll be going with 10" TDW12 and the span will be 22'8". They have end plates/caps that they bolt into. What I'll need to figure out is the 5'6"x8'6" cutout in the right rear for passing between floors. The sales guy wasn't very knowledgeable and passed me on to the engineers, who i left a message for and haven't called me back.
https://www.clarkdietrich.com/sites.../Catalogs/Structural/CD_TradeReady-Tables.pdf
/ New garage time! #451
At this point, it would be easy to just add another plate for height.
/ New garage time!
I am guessing this project has been a good weight loss program. :D
The last couple of projects I’ve lost about 40lbs. In between projects I just focus on not putting it back on. Coupled with 3 cracked teeth a year ago that put me on a liquid diet for 6 months, the pounds just fall off!
/ New garage time!
Getting there! Headers above the garage doors finished, end plates in all 4 corners so I'll have something to nail the drywall to. Left and rear walls straitened. Whoever had the idea to put on a 3rd top plate, good call. I did just that. Still getting used to walking on the planks on top of the scaffolding. I've lost my balance and fallen from great heights a few times in my life, so I'm a bit cautious. Tomorrow is the 3 top plates on the right and front.
To top it off a rainbow appeared and at the end of the rainbow, my garage!
/ New garage time! #454
Making great progress 🤙🤙
/ New garage time! #455
The rainbow must be a sign of approval.:rainbow:
/ New garage time! #456
Either a pot of gold or a money pit at the end of the rainbow, your call.
/ New garage time! #458
Are you going to "weave" the top plates at the corners?
/ New garage time!
Yes, already done with the rear corner. Also no seam is over top of another seam and every seam is over top of a stud.
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
