New garage time!
/ New garage time! #1,201
Are you going to fill up the planter with dirt behind the blocks? If it was me, I would drill some holes in your concrete along the path of the blocks so I could put a short length of rebar into the concrete. It wouldn't have to be very long, just enough for the concrete inside the blocks to have something to lock onto.
/ New garage time!
Yup, I'll be drilling and putting rebar every few feet, then filling that block with concrete. The corners are already done.
/ New garage time! #1,203
Are the blocks sitting on a footer?
/ New garage time!
No. But the blocks arent' going more than 2 high, so I don't think it'll be a problem. This slab is 60 years old so the settling has been done and there is lots of wire in there.
Also some of htat concrete is nearly a foot thick. From about page 10 in the thread:
/ New garage time!
Using old concrete, when i mixed it, once it set, it just crumbled. Not good at all. It turned to sand in my hands when I grabbed a piece. So I ripped the 3 corners up, they came up with no trouble. Cleaned the surface, got new concrete/lime/sand, mixed it up in 3:3:12, and laid it.
Once I'm done the full first level, I'm drilling and putting rebar in to pin the blocks. It's going slow, but winter weather is really hit and miss. Today was a rare 50f.
/ New garage time! #1,206
There's something very satisfying about laying blocks!!!
/ New garage time!
Got more block laid, despite the wind. My string line was blowing all over the place, and my wheel barrow even blew over towards the end.
Then i noticed i had a slight injury on my finger that I didn't feel because I couldn't feel my fingers. Once I got the feeling back, it was not great.
/ New garage time!
The real bummer is tomorrow is the last day above freezing, so i have to finish laying the block. Then comes the big freeze. I cleaned my finger up mostly and bandaged it, but it's not the only one that got chewed up.
/ New garage time! #1,210
I like laying block too, but my tennis elbow starts kicking in from gripping the block. Same as spitting firewood, I have to break it up with days between. And I never played tennis.
/ New garage time! #1,211
Ouch, that limestone is no good for your blood. Hope you don't play guitar for a living.
/ New garage time!
My issue is my hands, bad arthritis in my thumbs. If I push to hard, like last time, I couldn't hold more than a coffee cup for a week without intense pain.
/ New garage time!
Oil guy came to fill up the house. I asked him to also fill my 2 55g drums as well. I got my fueling station out of the old garage and into the shop last night, easy with the barrels empty. He was nice enough to fill them for me. Then I got my pump and power hooked up, and the barrels into place. Added my diesel additive as well. I should be good for a while.
/ New garage time!
My weber rollers were to high for my bandsaw. So I made some adjustments to them. I was concerned about some questionable reviews on the saw, some said it's precision leaves something to be desired. I haven't found that on mine so far.
/ New garage time!
I was putting some stuff on the second floor of the garage, and as I was riding the elevator up, something caught my eye. One of the joists didn't look right.
At first I thought my eyes were playing tricks on me. The joist looked bent. And a few joists beyond it. And while it's hard to tell it looks like it goes all the way down the line.
Everything is still very secure, i looked for other joist not looking uniform, but didn't see any spots other than down that line. That side of the building is unprotected from any wind break. So I'm wondering if the side wall is catching wind in such a way that it's somehow causing a bend in the joists down that line, since that would be the weakest point closest to the wall.
Forgive the POS level, i just wanted to grab a strait edge to see if I was seeing things. It looks like the bow is on the top as well as the bottom.
/ New garage time! #1,216
What are those joist made out of? I thought they where metal, but the way they are bending, it doesn't look like metal.
I think you need to call the manufacturer that made them, and talk to an engineer there. Something like this will only get worse over time.
/ New garage time! #1,218
With the bends occurring above and below the port/cutout, I would think that is the culprit? Maybe you could weld some plates over the holes?
/ New garage time!
That's an idea. I have to figure out what's actually bending. It doesn't look like it's dropping, more like compressed since it's bowing at top and bottom. I checked the other ports down the line and it's not happening there. It's only happening on the second porthole.
I have no idea when it happened, if it was a one time thing during a heavy storm. I think i may plant some tree's or something as a wind break because that side wall just does nothing but catch wind when it storms.
/ New garage time! #1,220
Unless there are signs something is about to break I probably wouldn’t worry about it. Steel bends and forms a little like wood.
2007 Yamaha Rhino 4x4 Side by Side Gas Cart (A64194)
2007 Yamaha Rhino...
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2015 Ford F-250 Ext. Cab Pickup Truck (A64556)
2015 Ford F-250...
2007 Toro Z-Master 72in. Zero Turn Commercial Mower (A64553)
2007 Toro Z-Master...
