New garage time!
   / New garage time!
So I got half way through running the wires, then realized I forgot to do it the way that I wanted. I wanted the first drop to be closest to the wall, but I was wiring the last drop first, and ran it against the wall. After 3 sets I realized it and kicked myself.
Thankfully, I replaced the nail hangers with screws, so it was easy to unscrew them half way and redo the wires in the proper order and spacing.
Then I finished the 12 runs, 2 per inverter, and started tidying up the board. The last 2 inverters will be here monday.
Tomorrow I'll start adding breakers to the new panel. Then the breakers to the grid panel, off position of course. Then i'll take up any slack and trim them to the correct length. And another trip to the steel store for more panel mounts.
   / New garage time! #1,392
Much better!
   / New garage time!
Got the last 2 inverters up. Now it's must a matter of days of wiring. I'm looking forward to powering up the system.
   / New garage time! #1,394
Got 2 more panels up. It's finally starting to look like something.
Drilling these holes is killing me, my shoulders hurt so much. I can't put my weight on it so I have to use shoulder and bicep muscles. It' hurts pretty bad after about 2 and there's 4 per panel.
So I made the HoleMaker 300™, patent pending, by modifying a drill press to be a portable drill press that I can clamp to the rails and drill more easily.
But when I try to weld the thing, it just falls off. I am getting penetration, but after it cools, it just comes off. What kind of metal is this and how can i weld it?
Almost looks like your shielding gas is turned off and you're running solid wire.
   / New garage time!
I’m running gasless flux core. I got a solid puddle back and forth, but the metals wouldn’t mix.
   / New garage time!
I had my hands in the inverter wiring it up. Then the power went out. And I thought "did i do that?"
I had to go down a mental check list to see if it was something I did. It wasn't.
This is the exact reason I'm doing this bs. 15 minutes later electric company texts, "sorry your power is out, we dont' know why, we'll have it on by midnight."
   / New garage time!
No one talks about the wiring... Or if they do, I skipped ahead.
Current sharing and communications cables installed.
   / New garage time!
Finished up the ac on the inverters, and did the new inverter breaker box feed lines. Tomorrow I'll do the grid panel and maybe get the battery shelf set up.
   / New garage time!
I cleaned up the main box and free'd up 6 breakers to power each of the inverters. I'm going to have so much room in the new box, it'll be great not dealing with such a cramped space.
   / New garage time! #1,400
From what I've read, the electric instant hot water heaters use so much power to heat the water that there isn't a savings using them over a conventional electric hot water heater. The real savings with instant hot water heaters is with Natural Gas or Propane. Especially if you have the supply line big enough to supply the amount of gas needed.
The advantage is that you have it at point of use, less water waste and no storage losses. It's a gain over resistive heaters electric but very dependent on electricity vs gas prices as you said.
Oh, it's also an advantage for places that only have cold water pipes, you don't have to replumb.
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
PAZA 3PT SPIN SPREADER (A52708)
PAZA 3PT SPIN...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
New Wolverine 78in Skid Steer Land Leveler (A59000)
New Wolverine 78in...
