New food plot
   / New food plot #1
Ridgewalker
Platinum Member
St. Francois Mountains of Missouri
NH TC29
I'm putting a small food plot on some land I recently bought.
I want to grow clover and chicory on about 1/4 of bottom
land. It's currently covered by leaves and a few weeds, small
trees.
What's the best way to ensure success? Should I treat with
12/12/12 now to give the soil a boost?
Also, what is the best time of year to plant the clover? I am in
Missouri near STL.
TIA!
   / New food plot #2
First thing is you need to do is to get a soil test. Clover will benefit from fertilizer not so much from the N because it produces its own from the atmosphere. If you have an extremely low or high PH all the nutrients you add will be locked in the soil and the plant won't be able to utilize them so it makes sense to amend the PH before dumping $$ in fertilizer that the plant may not be able to utilize.
   / New food plot #3
Get a soil test now. Mow the area asap. Lime asap according to what the soil test recommends and work it into the soil (lime takes several months to "work".) Seeds that laid dormant in the soil will sprout, so you'll want to kill them once or twice this summer. You can either hit the area with glysophate (generic Roundup) a couple of times as the area greens up, or if you want to provide food at the same time, you can plant Roundup Ready soybeans in the plot and spray a couple of times. This will give your cover a weed-free start and provide a much nicer plot down the road. Plant your clover and chicory with a nurse crop of winter rye this fall around Labor day. Add the recommended fertilizer at that time. The rye will die out next spring and you'll be left with a thick weed-free plot of clover and chicory.
2022 GORILLA  20FT EQUIPMENT TRAILER (A54607)
2022 GORILLA 20FT...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2023 Top Hat Industries Cool Down Trailer (A52377)
2023 Top Hat...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
