New-fangled Old-timey slip scraper
   / New-fangled Old-timey slip scraper #11
Yep, then they were adapted to the tractor 3 point.
I had one that was reversible and 36" wide:
A 30" reversible pan was the first tractor implement I bought. Still have it and when I am moving dirt any distance, I will put it on and take a FEL bucket and a rear scoop full each trip. A full scoop makes a decent counter weight for the FEL and increases what I can move each trip by about 50%. I have actually never pulled it, I always set it up to push it like your pics have it.
   / New-fangled Old-timey slip scraper #12
I've noticed while watching videos of the rear scoops is that the operator has to yank fairly hard on the rope to release the trip lever and dump the load. I suppose the difficulty is determined somewhat by the balance of the load. I later noticed that some (or most) of the operators will set the load on the ground before tripping the release and then raise the 3PH to dump either stationary or on the go. Makes sense I guess.
   / New-fangled Old-timey slip scraper #13
View attachment 542404 View attachment 542405 View attachment 542406
Moved a lot of dirt with it back in the good old days, since the tractor didn't have a loader.
I've seen a lot of these scrapers over the years but I'm thinking this may be the first picture of one with a load. I'll bet the cylinder top link is quite useful for setting the cutting pitch while loading as well as dump assist?
   / New-fangled Old-timey slip scraper #14
What's in a name? That which we call a rose
By any other word would smell as sweet;
My Dad had a slip scraper, although I never heard him refer to it as such -- he called it a "scoop." I remember driving our AC G while he handled the slip scraper/scoop in smoothing out stream crossings.
Steve
   / New-fangled Old-timey slip scraper #15
Back when on the farm we had a four horse Fresno.
   / New-fangled Old-timey slip scraper #16
Yep, very useful. Made the dirt scoop work better, also the box blade, the brush hog and everything else on the 3 point.
The hydraulic top link came with a 3 point forklift that I bought a several years after using everything with a standard toplink, so I really noticed the difference.
   / New-fangled Old-timey slip scraper #17
I remember being on the handles of one of those scrapers. I had some "Flight Time" when it hit a root or a rock.
Yep me too, piloting one for my father. He had a ford bronco he liked to use as a tractor, hook on of those scrapers up and you'd do just fine, until you hit something that didn't want to move.:dove:
That's just part of the learning process and you learn quick to let go of the handles when it stops. If you're working in good loose dry material, by letting the handles slowly over to dump, you can spread it fairly evenly.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
