New clutch time
/ New clutch time #1
repete
SW Washington
L2550DT IH584-4WD
After 5,500 or so hours the clutch on the L2550DT finally bit the dust. About three hundred dollars to replace both discs, throwout bearing and engine main seal due to a small leak. Never had this little guy in half before. Hopefully just discs and not pressure plate.
/ New clutch time
While in there, Replace the pilot bearing in the engine flywheel... If it did not slip a lot and overheat the pressure plate will likely still be good...
I forgot to list the pilot bearing as well.. I just noticed it slipping so hopefully I caught it in time. I thought I felt something not right after adjusting the clutch freeplay so I put it on the hill on the driveway and let the clutch out in 3rd high and the engine revved and tractor only moved slowly forward. Enough tests, in the shop it comes.
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
UNKNOWN TANK MANIFOLD (A63569)
UNKNOWN TANK...
ATS Power 50 TON Shop Press (A64047)
ATS Power 50 TON...
Kuhn SR110 GII Speed Rake (A64047)
Kuhn SR110 GII...
2025 MB27 27in Mixing Bucket Skid Steer Attachment (A61572)
2025 MB27 27in...
207923 (A63290)
207923 (A63290)
