New Carport
/ New Carport #41
Derek...I'm working through A1RVS as well and planned on preping my site similar to CHAMPY's pics earlier in this thread. I figure any settling over time can be easily fixed by moving some of the stone base where it's needed.
/ New Carport #42
I like the metal carports. They are generally alot for the money, but they dont hold up to trees very well. Heres what happens when a 12" tree falls on the corner of a metal carport. I cant complain, it protected my tractor and truck that was sitting under it. Insurance paid me to replace it but I still havent, and that was several years ago.
/ New Carport #43
Engine66 said:
Unfortunately, my zoning administrator takes any type of building very seriously and requires a full-blown 5 page permit, inspection, the works. ANY assembly of materials is considered a structure...and must be permitted. Even a pre-fabbed plastic shed requires a permit, fees, inspection with measuring tape, and a "pretty please with sugar on top" attitude to get approval. A neighbor of mine built a garage for $3,000....maybe it's 20x30, simple stick built with T-1 siding and metal roof. He told me it was appraised by lister for $30K for property tax purposes. Ouch... I think this type of carport will help me avoid such a hit and give me the shelter I need.
Pretty much every region is going to be different. Here there would be setback requirements, and probably other limits if the interior was enclosed vs. a carport like arrangement.
The tax assessor has quite a bit of latitude in setting the value for a house. Unless one is in a subdivision of cookie cutter buildings, or the assessment states something about the outbuilding, it is hard to determine whether the assessment has 10-20k tacked on for a 'temporary' building.
I have a house with a deck that is not attached at all to the house. Technically, the deck is "temporary" (the reason for detachment is to reduce thermal bridging, not to avoid taxes). The house is full custom and unless the assessment stated something about the deck, I'd be SOL on that argument. Since the town is fairly easy to deal with, and the deck would sell with the house anyway (i.e., increasing the property value) it is reasonable to have some value added to the assessment...
/ New Carport #44
Dmace,
How is the new carport holding up to this years record snowfall?
/ New Carport
I will try to put some pictures up later but so far, it holds up very well. It had about 20" of snow and ice on it before we got that freak rainstorm. I used the snow rake to remove as much as possible just because. Here is a picture of it after most of the snow was removed:
Right now it has another 20-24" on it but it's a very light fluffy snow, so I am not worried about it. I will definitely close in the back and sides this summer as the snow likes to blow in and the piles are falling in from the sides.
Ray,
It hurts to see that carport with a tree on it, but it looks like it saved your equipment. If that was my old fabric carport, everything in it would be gone too! :eek: I took down every tree with in about a 20ft radius of the carport site before it was delivered just in case. :cool:
/ New Carport #46
Derek,
Your carport is getting a good workout this winter. How is it holding up? I plan on taking a trip down to A-1 and talk to them.
/ New Carport #47
Bob_Young said:
I've been thinking of one of these as a firewood shelter. Getting tired of trying to burn damp wood and the makeshift arrangements for keeping it covered haven't worked that well...in addition to being eyesores. Anyone using theirs for firewood? Stone floor sounds about right with old skids to keep the wood up a little.
I thought of devoting half to two-thirds of it to firewood and then leave one side open so as to back in implements from the side.
Bob
I've seen several in our area used exclusively for firewood - mostly with the outside-the-house type of woodburner. I think it is a good idea and a lot easier on the eyes than tarps, old plywood, etc.
/ New Carport
rfmr said:
Derek,
I wish I had taken a picture yesterday when it had over 24" of heavy snow and solid ice on it. That was before we got another 7" of snow and 5-6 hours of heavy downpours. The carport is holding up very well and I never was worried about it's structual integrity. I cleaned off the roof last night before all that rain froze and feel much better just with peace of mind. I will most definitely being closing the sides this summer, all the snow from the roof falls into the carport and I have to plow or shovel it out. This is one strong carport.
/ New Carport #49
Anyone have any ideas on how to rodent-proof a fully enclosed garage on road base. I don't want the added expense of a concrete pad. In the SW, pack rats and mice are a major problem chewing up vehicles, which is one reason I want the garage.
How tight are the corners of these buildings? I'd expect mouse-sized spaces in the corners. Additional flashing needed?
How did you compact the crushed rock pad? (I think I'd top the rock with grinder fines to make it smoother). Any other tips on constructing the pad would be appreciated. I have a TBL but no blade to work with.
Charlie
/ New Carport #50
Might be a real challenge to keep the rodents out. I have an attached garage with a concrete floor and the mice chewed their way into it through the weatherstripping on the doors.:(
I might need a cat!
/ New Carport #51
I have had the same problem with door weatherstripping on a stucco garage. I used a roll of 8" aluminum flashing and bent it along it's length into a U shaper (harder to do than you might think - needs lots of clamps (pop rivets pull out). Then I screwed the U along the bottom of the door. The flexibility of the aluminum made for a nice seal except in the two corners. I just keep a brick on the outside of the door at the corners to bar entry there.
I'm more concerned with burrowing rodents which are very persistent.
Charlie
/ New Carport
With all the rain due this week, I didn't want to leave the 2ft of heavy wet snow on it just in case. It is holding up very well but I don't like to take chances when there is over $30k sitting under it. :eek:
Upon close inspection, I did notice that the roof trusses are stressing enough to start flexing where they are bolted to the vertical post. When I close in the sides this Spring, I think I will reinforce them better.
I feel much better now! :D
/ New Carport #53
PA hayseed said:
I have thought about buying one of these, but I am worried about snow loads and I have alot of high wind. Wonder if this would wind up in kansas, or maybe NJ, if we got some more 60-70 mph gusts.
Anyone who has had one of these can you enlighten me on their wind resistance? I know I can anchor it, but wind is wind, and I am not sure how tough these things are.
I'd love to have a wind turbine up here, but they are too cost prohibitive.
I live in the mountains in PA, and I catch alot of wind especially in winter.
As I understand it, there are two components to wind resistance to consider: uplift and overturning.
For a carport with open sides overturning isn't much of a problem. You design the anchors for uplift. In New Hampshire the max local unit wind pressure is 30 psf, so the anchors for that 18x21 carport have to be designed to resist an uplift of about 14,000 lb.
/ New Carport #54
Anything here on skids is exempt from property tax.
/ New Carport #56
i have 3 of these up and enclosed on my property,enclosed them myself with the same steel as on the roofs,considered a temporary structure as long as there is no concrete floor,i used stone and old concrete form faces on the floor,used screw anchors every truss to hold it down,they hold up great to any snow we have had,3 ft during our october disaster.ill try and post some pics
2461 (A58376)
2461 (A58376)
Willmar Fabrication 915 (A64119)
Willmar...
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A61572)
2015 JLG G12-55A...
2010 FORD RANGER SINGLE CAB PICKUP TRUCK (A59912)
2010 FORD RANGER...
275 GALLON POLY TOTE W/ CAGE (A64281)
275 GALLON POLY...
Asphalt Melter (A61572)
Asphalt Melter...
