New BX2380 Owner
/ New BX2380 Owner
What size deck do you have? Be very careful on any inclines - it is a very tippy machine if you don't have rear wheel spacers or liquid ballast in tires. I put 2" spacers on mine, and the rear tires don't clear the rear deck wheels by much. If you have a 54" deck, not sure if spacers can be used.
It has the 60" deck. Where did you find the spacers?
/ New BX2380 Owner #23
these are the spacers I have…
/ New BX2380 Owner #24
Wow that is cheap !! On those machines it makes a huge difference that the Jeep spacers fit. There are a bunch of vendors selling spacers (including most Kubota dealers.) Six inch ones I bought for a B2150 little larger Kubota were over $500 a set. At least on my B2150 with 60" deck the rear wheels would not clear the MMM deck and I had modified mower deck frame pieces made to bypass the problem.
/ New BX2380 Owner #25
Instead of chaining up the box blade, get a Quick-Hitch. Then it's very easy to just drop any three point implement. You can often hook up without getting out of your seat. The loader is super easy to drop also.
Then you'll have freedom mowing.
2018 Nissan Pathfinder SUV (A64557)
2018 Nissan...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2019 PITTS CONTENDER LD35-22DC RGN LOWBOY TRL (A64277)
2019 PITTS...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
