New BX2380 Owner
/ New BX2380 Owner
What size deck do you have? Be very careful on any inclines - it is a very tippy machine if you don't have rear wheel spacers or liquid ballast in tires. I put 2" spacers on mine, and the rear tires don't clear the rear deck wheels by much. If you have a 54" deck, not sure if spacers can be used.
It has the 60" deck. Where did you find the spacers?
/ New BX2380 Owner #23
these are the spacers I have…
/ New BX2380 Owner #24
Wow that is cheap !! On those machines it makes a huge difference that the Jeep spacers fit. There are a bunch of vendors selling spacers (including most Kubota dealers.) Six inch ones I bought for a B2150 little larger Kubota were over $500 a set. At least on my B2150 with 60" deck the rear wheels would not clear the MMM deck and I had modified mower deck frame pieces made to bypass the problem.
/ New BX2380 Owner #25
Instead of chaining up the box blade, get a Quick-Hitch. Then it's very easy to just drop any three point implement. You can often hook up without getting out of your seat. The loader is super easy to drop also.
Then you'll have freedom mowing.
Bomag Roller (A63689)
COLUMAN POWERMATE 60 GALLON AIR COMPRESSOR (A64281)
COLUMAN POWERMATE...
2014 Mercedes-Benz GL 450 4MATIC AWD SUV (A61574)
2014 Mercedes-Benz...
2016 HAMM HDT90IVV DOUBLE DRUM ROLLER (A64279)
2016 HAMM HDT90IVV...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
