New Branson 2515
/ New Branson 2515 #41
I don't understand why manufacturers can't put all the goodies on smaller tractors. The 2515h will not have tilt or extendable ends on the lower arms. It aggravates me to no end. I want all of the good stuff from the larger tractors. One thing that concerns me is will 25HP be enough to handle a heavier frame and loader??
Maybe ask your ordering dealer if those extendable arms can be ordered as an option with your tractor? We do get pretty spoiled on the Branson line, as a whole bunch of "standard" Branson equipment must be ordered as "optional" add-ons with other brands.
And it really doesn't take much hp at all to just move the chassis around and make the loader go up and down. The most important question on hp is, what attachments are you needing to power off the pto, and how big are they? That is really what drives your individual hp requirements, and that varies greatly between different users.
/ New Branson 2515 #42
Where did you get that info? I'm pretty sure the engine is one of the few changes versus the other higher HP models.
Anyways, I've seen dealers saying the it might come out in the end of the month or the next one.
I asked one of the product managers about the tilt and telescoping lift arms. Said that the telescoping lift arms would not be available.
/ New Branson 2515
I agree with Slowpoke. 25HP is plenty for loader work and moving the tractor around. Also for pulling a box blade or a leveling blade, should be fine.
Now depending on yours needs and size of PTO driven implements, 25 hp might be on the low side for that size of tractor.
/ New Branson 2515 #44
I don't think they offer telescopic arms on any of the 15 series.
Why not just convert to a quick hitch? That is even better than telescopic arms. Don't even have to get off the tractor to hook up to a implement.
/ New Branson 2515 #45
I guess I just have a case of the "what ifs". My Dad has a Red Belly Ford that ran a 5 foot bush hog, but not sure if the 2515H would run that since it is a hydro.
/ New Branson 2515 #46
Depends on what you are cutting. It will run a 5 foot, you may have to go slower and maybe not take full swaths.
/ New Branson 2515
I have the 35 HP model and I have 3 PTO implements for it.
A 60" rototiller with 4 tines per flange, a 52" brush mower and a 4 spade spading machine. I won't talk much about the mower because we use high strength chains instead of blades and it eats a lot more HP that a conventional blade mower, so it's hard to compare both.
The 60" tiller covers the width of my tractor (55") just fine. I have yet to see the tractor bogging down with the tiller. I usually run it with the 540E PTO gear without a single problem. I'm pretty sure I could run a bigger one, but there is not need. I do have a video of it working.
The spading machine, it's very cool to see it working. I got it with another machine a few years back. Here is a nice explanation video: Gramegna Spading Machines - YouTube
/ New Branson 2515 #48
I run a 6' brush hog off of 32 pto hp without any problems. Unless the grass is very thick and also higher than the hood (both), I don't have to slow down at all while cutting. I think you'd be fine with 25 hp and a 5' cutter, as long as you're willing to slow down through any really thick tall grass. The added benefit of the hydro trans makes it easy to moderate your tractor ground speed while keeping the engine (and pto) speed at full rpms for mowing.
/ New Branson 2515 #49
I just saw the local dealer I bought my 3015H from posted an add that they have a new 2515 in stock.
/ New Branson 2515 #50
My closest Branson dealer is 132 miles away. I have a TYM dealer that says he will send the parts and pay for a repair center to fix it. Not sure which one I would choose.
/ New Branson 2515 #52
My Guess is Not For Long:laughing:
That model Dominates it's Class Spec wise.
I Really think this model will sell like Hot cakes.
Lets relist some Specs
All the capacities of the 15 series.
Including an FEL that puts all other 25 hp CUT's to shame. total height and lift to full height at the pin.
2200lbs tofull height of 104 inches breakout force 3660 lb.
larger displacement 25 hp engine with max power at ~`2200rpm
Edit looks like something changed since this thread started the original sheet showed a 4 cylinder running at 2200 rpm now 2600 with a 3 cylinder???
Virtually no emission system
Hydromax 3 range hydrostat with cruise control
540 and Economy PTO that is also fully independent
Nice Suspension seat
2515R – Branson Tractors
BL15 Loader – Branson Tractors
[AT TACH=CONFIG]646313[/ATTACH]
/ New Branson 2515 #53
/ New Branson 2515 #54
Well 25 hp used to be quite the tractor;
Farmall H was called a 2 bottom plow tractor,
Drawbar (claimed): 19 hp [14.2 kW]
Belt (claimed): 24 hp [17.9 kW]
Drawbar (tested): 24.17 hp [18.0 kW]
Belt (tested): 26.20 hp [19.5 kW
/ New Branson 2515
They finally added it to the website. Cool.
On the other hand, that site is a mess. Wrong specs all over the place. The Global website is slightly better but still lacks lots of updates.
I know part of the lower cost on Branson tractors comes from little to no advertisements but a good proper website is a must in the current times.
/ New Branson 2515 #56
And would cost them next to nothing to improve. I really don't understand cost cutting in advertising and marketing. People are always looking for a reason to buy your product, not a reason not to buy it.
That kind of penny ante, shoddy marketing is mystifying.
/ New Branson 2515 #57
I agree. Branson could help their sales quite a bit just by providing a little more accurate specs and keeping their website up to date. This was one of my concerns when I bought mine. I only settled on the brand after seeing them in person. Some do not understand what they can see, only what they read.
/ New Branson 2515 #58
I too wish they would update their website. Just correcting the errors and revamping the models displayed to only showing the currently produced ones would help. But taking a que from other competitors and setting up a "build your own" section and a comparison section would be great. C'mon Branson, bring your website up to the early 2000's... I mean you'd only be 20 years behind then.
:laughing:
Branson: Building a great product, and then hiding it from the world.
/ New Branson 2515 #59
I just looked at the sheet posted at the first page, it said the engine was the 1.7 liter but 2200 rpm was where it made 25 hp. Don't recall seeing the 4 cylinder a2000 for the 25 horse. The a2000 is in 37 horsepower bransons so that would be majorly detuned.
/ New Branson 2515 #60
Yeah -sorry bout that, posted and had to leave to get supplies. and didn't remember to edit that.
I do believe you are right, although it is interesting that they raised the RPM's by 400.
Still a Class leader, I think.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
1997 LEDWELL 48FT DOVETAIL TRAILER (A67714)
1997 LEDWELL 48FT...
2005 CATERPILLAR TH460B TELESCOPIC FORKLIFT (A65056)
2005 CATERPILLAR...
2006 HONDA ACCORD (A65057)
2006 HONDA ACCORD...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
