Backhoe New Backhoe
/ New Backhoe #1
mike48
kingsland,ga
branson 2910i
Hi All,
Just got a new backhoe have a branson 2910 and BH760 hoe really works great dug up some nice size stumbs today most of them pine 6" to 14" will send some pics as soon as I can the hoe has a 8' reach on It a lot of power run the rpm's around 2300 and that works well this hoe Is a upgrade from the 7620 .
Mike
/ New Backhoe
Hi All,
some pics new and old with new backhoe It works real well have dug some big stumps out have more pics later saved alot of time with this hoe wish I had gotten it early on. but having fun doing work with it.
Mike48
/ New Backhoe #3
Mike,
Nice looking property. Good job with those stumps. Typically takes me a few to even 3 or more hours to pull some of my stumps. Breaking those roots is the tough part.
Great Job,
Jim
/ New Backhoe
Thanks,
yes know what your saying I got a few big one's also had to use the chainsaw to cut the feeder roots not bad after doing that. what size tractor and hoe are you running? anyway sure beats a shovel :> ..
Mike48
/ New Backhoe
Hey Jim,
was looking a your profile nice setup, should have looked there first. good to know that you are a ham also and work with tractors that's great, maybe talk to you on the air sometime.
Mike48/n4xt
/ New Backhoe #6
I have a Branson 3510 and I got a good deal on a Jinma Hoe. I did have to build a sub frame to fit. I run my RPM at about 1400 and have plenty of power. Have you tried lower RPMs?
/ New Backhoe
nice tractor and hoe, yep did lower the rpm,s and still digs ok and not as jurkey at 2300 the dealer told me to run at.
Mike48
/ New Backhoe #8
Mike
I just bought a 3510 with the same BH...Mine seems really weak, I have the control under the seat open and the bucket works fine.
I dont really know what to expect of it. But it will bog down really easy. I was only running mine at 1500 rpms and maybe that is the problem.
Do you have any idea what to expect, are you familiar with other backhoes?
/ New Backhoe
Hi,
sorry been out for sometime, well you really need to run the rpm at around 2000/2300 for this hoe to work and have the pressure that It needs, I have dug out some big pine stumps with It had to cut some feeder roots with my chain saw to help out. so just take your time and work It, and It will do the job. hope this will help out let me know.
mike48
CAT 320 CL GP Bucket (A68134)
CAT 320 CL GP...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2015 KOMATSU PC490LC-11 EXCAVATOR (A65056)
2015 KOMATSU...
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
master diesel generator (A64553)
master diesel...
2009 JACK COUNTY KILL TRAILER (A67714)
2009 JACK COUNTY...
