New Attachments....help id??
/ New Attachments....help id?? #1
2kpsd
Martell, NE
Montana Limited 300DTC
Hi - saw an ad in the nickel for farm equipment. Ended up buying a side-by-side disk and a 6 ft 360-degree rotating blade. There is an id plate on the disk which I will attach a picture of. Just curious as I am a newbie to all of this if I got a good deal or if the equipment is good or not. I paid $50 for the disk and $50 for the blade.
another of disk
another of disk
id label on disk
id label on disk
Blade pic 1
Blade pic 1
Blade pic 2
Blade pic 2
disk on 790
disk on 790
Pulled the disk around tonight in the area that is going to be the riding arena - did a very good job working the dirt that hasn't been worked for a long time. Several passes was all it needed. Will probably paint the blade jd green to match better over the weekend.
/ New Attachments....help id?? #15
Some folks may not agree with me but I think you did good getting both for $100. The disc looks like it has a broken disk but it can be replaced if you feel it is necessary. The main thing is will they do what you need. I would have gladly paid the money if I did not already have a disc and a blade.
Farwell
/ New Attachments....help id?? #16
Farwell
/ New Attachments....help id?? #17
Dearborn was one of the best disc makers around in my opinion. $50 for that is the better of the two deals, although the blade for $50 was a steal also.
I'm actually surprised you can pull those discs so well with that tractor as they are pretty large for a small CUT.
Good deal, be very happy you got them.
John
/ New Attachments....help id?? #18
John
/ New Attachments....help id?? #19
Yeah, $100 for the pair is a lot of use for little money. The blade looks fine. The disc is okay.........using for arena conditioning is one thing, but you won't get anything out of it for ground prep or fire prevention.
/ New Attachments....help id?? #20
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2010 John Deere 7330 Premium (A64126)
2010 John Deere...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2022 EZ-GO ELITE...
