New Attachments....help id??
/ New Attachments....help id?? #1
2kpsd
Martell, NE
Montana Limited 300DTC
Hi - saw an ad in the nickel for farm equipment. Ended up buying a side-by-side disk and a 6 ft 360-degree rotating blade. There is an id plate on the disk which I will attach a picture of. Just curious as I am a newbie to all of this if I got a good deal or if the equipment is good or not. I paid $50 for the disk and $50 for the blade.
another of disk
another of disk
id label on disk
id label on disk
Blade pic 1
Blade pic 1
Blade pic 2
Blade pic 2
disk on 790
disk on 790
Pulled the disk around tonight in the area that is going to be the riding arena - did a very good job working the dirt that hasn't been worked for a long time. Several passes was all it needed. Will probably paint the blade jd green to match better over the weekend.
/ New Attachments....help id?? #15
Some folks may not agree with me but I think you did good getting both for $100. The disc looks like it has a broken disk but it can be replaced if you feel it is necessary. The main thing is will they do what you need. I would have gladly paid the money if I did not already have a disc and a blade.
Farwell
/ New Attachments....help id?? #16
Farwell
/ New Attachments....help id?? #17
Dearborn was one of the best disc makers around in my opinion. $50 for that is the better of the two deals, although the blade for $50 was a steal also.
I'm actually surprised you can pull those discs so well with that tractor as they are pretty large for a small CUT.
Good deal, be very happy you got them.
John
/ New Attachments....help id?? #18
John
/ New Attachments....help id?? #19
Yeah, $100 for the pair is a lot of use for little money. The blade looks fine. The disc is okay.........using for arena conditioning is one thing, but you won't get anything out of it for ground prep or fire prevention.
/ New Attachments....help id?? #20
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
SDLanch SDLGC80 (A64127)
SDLanch SDLGC80...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
