New and New problem
/ New and New problem
Well i found a hammer puller in Northern Tool that is doing the job of getting the piston sleeves out. I got one out and of course the other is a problem. ALso got the radiator boiled out at a shop. New parts are in just waiting on a manual and time to just dig in. If I find my camera cable I can upload some photos what I am doing. Also just picked up a big torque wrench that goes up to 250lbs. doe anyone off had know the head torque for a 2210?
thanks,
E
Well just about finished putting the motor back together. Hot day. Had to go in side a few times. It has been slow to put together with Family and other projects. Just got a zero turn mower used and it is fun to drive. I will end up selling my 72 inch finish mower later on. Anyway It has been pretty nice puting the motor back together. One tid bit that was helpful was that i used one of those chain oil filter wrenches to turn the crank shaft. Worked out well when I was adjusting the valves. Only thing i have left is clean up the oil pan cover and put radiator fluid in and check for leaks. Hope to get to it later next week.
have a great weekend.
Erick
Well I got it running! Hurray! I feel great about it. First time for pistons, rings and sleeves! It seems smoother and no smoke out of the muffler. I am keeping the side covers off for now just to monitor fluids and leaks. So far just a drip out of one of the bolts on the oil pan section. It sort of stopped after a few min of running. Hope fully it will hold. We shall see.
later
E:cool:
Wel i got to use the tractor quite a bit this weekend. SO much more power than before. I thought it had good power but not it hardly bogs down at all. I will just loose traction before it starts to bog. I did have to put a little radiator stop leak in. I had bad radiator fluid back with I bought it in 2000 and it cracked around the freeze plug. I had to do a old trick a guy tought me with using a Dremel tool on the crack and then put some JB weld on it. It fixed 99% of the leak back then but i had to put some stop leak in to finish the weeping off. Now that i had cleaned up every thing this time it must have cleaned the weeping crack again. ANy way a bit of stop leak and now good to go. It sounds so different than before not so much clanking that I was use too.
later
e
2
http://www.tractorbynet.com/photos/showgallery.php/cat/500/ppuser/54795
Photo of taking motor apart.
I tried to insert a photos but that did not work so i just sent the link to my photo gallery.
later
E
/ New and New problem #17
I looked over your pics of the motor tear down and noticed that the old pistons had the oil control ring below the wrist pin and the new had them above--was there a design change somewhere along the way?
Mike
you know what I did not even see that! LOL! that is really weird. I wonder if it was a old design or just the wrong pistons were in it? Maybe someone will shed some light on that! LOL!
Erick
/ New and New problem #19
Erick
It had the right pistons, the pistons you used are for a YM2000, same size, no problem.
Danny
Thanks Danny for shedding some light on the subject. If the 2000 has similar size pistons I thought a 2210 would have bigger displacment? I know the 10 on the 2210 is for shuttle shift but was wondering what else is different in the motor? I am actully hopefully getting a ym2000 this week from a guy and hope to fix it up to sell.
later
Erick
2025 MMS MS36C (A60463)
2025 MMS MS36C...
2016 Jeep Patriot SUV (A61569)
2016 Jeep Patriot...
2020 John Deere 6120E (A60462)
2020 John Deere...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
(INOP) 1996 FORD F150 SIN CAB TRUCK (A59823)
(INOP) 1996 FORD...
Ingersoll Rand 185 (A60462)
Ingersoll Rand 185...
