New acerage need tractor
/ New acerage need tractor #21
I dunno... I have a BUNCH of equipment and while "specialized" stuff is nice it's also yet more to maintain: I have two identical cars in order to help make maintenance less of a headache.
Not sure how rough your ground is, but I'm not thinking that I'd be using a ZTR on much of what I have to mow. I've got about 1/2 acre or so of "lawn" that is mowed with a conventional riding mower (not a box store mower), only a 42" deck though; I find that while it can mow fast, it doesn't necessarily mow well at high speeds- it'll mow grass fine, but the d@mn weeds seem to escape unless I slow down. But, while speed is definitely a factor, the other thing to consider is how frequently you have to mow. You can look at what you have, how fast your grass grows, take the approximate figures here that people have provided for deck and cutting speeds and calculate how much time each of your options would take. Is one clearly more cost-effective?
I've got probably about 10 acres that I'm mowing with my B7800 and a 5' rotary cutter: it's amazing at how well this combo can mow grass; if you don't require a golf-course turf-like finish then this might be a consideration (rotary cutters are pretty cheap). I have blackberries and tree debris to contend with, something that I would suspect would be harsh on a ZTR. MyB7800 isn't zero-turn, but it ain't the Titanic either; and, I'll guarantee that I have a LOT more to dodge than most folks. Much of your navigation can be optimized over a period of time as you adjust.
My B7800 sips fuel. Unless a ZTR is diesel, which is going to be in the $4k to $6k range (at least), it isn't going to be more fuel efficient. I'm a bit of a diesel snob; if I have to burn a bunch of fuel I'd rather burn diesel because I can safely store/trasport diesel whereas that's not the case with gasoline (not a fan of lugging around fuel containers, I've got a big tank that I have filled with diesel).
I'll toss in the idea of a flail mower here. I'm planning on getting one: it'll be for my new Kioti NX5510, it'll be a 7' flail. Popping on and off a flail should be, I'd think, much easier than popping on and off a mid-mount mower. Also, it's my understanding that flails are safer than blade mowers. A flail is going to be cheaper than the other options discussed here. Savings can go toward up-sizing the tractor and or the purchase of other productive tractor implements.
Regarding tires, ground conditions will dictate what kind of tires you should be looking at. I'm running R4s, and while I've gotten stuck pretty good, I will continue to run R4s. Only if you have a bunch of mud and or are looking to do really hardcore tillage would Ag tires make sense. Further, R4s are what you want for loader work: Ags don't rate as high for bearing weight. I've found that machine weight makes a big difference for traction (it's kind of one of those "duh" things!): after several years I finally broke down and put ballast in the rears of my B7800; I was always concerned about doing so with my soft ground, but since ballasting I have not seen any negative effects- and, if anything, I have to say that I actually disturb the ground less now because I'm not slipping/spinning.
If I had a lot of open ground/pasture with grass I'd bring in a couple/few grazers. That's what I'm planning on doing. My goal in life is to be a grass farmer and not a lawn mower.
Feel fortunate in that you can actually be in this position of having to decide :) (it's good to have options!)
What are the hydraulic remotes used for?
/ New acerage need tractor #23
They are used to extend and retract hydraulic cylinders that aren't part of your tractor, like to raise and lower the wheels of a disc, open and close a grapple, or raise and lower scarifies on a box blade, for example. You can also replace one of the lift arms and the top link of your three point hitch with hydraulic cylinders and make adjustments to the front/back and side/side angle of your implements. This is called a top and tilt setup, or TNT. You can also use remote hydraulics to power a log splitter or something else that uses hydraulic flow.
/ New acerage need tractor #25
I would agree that something bigger would be best. The 30-40 HP range would be good. We have 4 acres and we're looking for something smaller but couldn't pass up the deal we found on a Mahindra 3616.
I keep smiling Everytime we use it for something new and are so glad we got something bigger. It helps with mowing, bucket work, tilling, etc. It also has a cab. The cab is worth the cost, so much better snowblowing in the winter.
I'll maybe look at the bigger models to see if it's feasible to go that route. A cab would be sweet but not in the budget also I drove a jd 2025r with a cab and it was really loud inside. Plus I have lots of winter clothes from work
/ New acerage need tractor #27
Not sure at what power levels/sizes common rail [CR] diesels come in to play, but for sure, CR engines are a lot quieter. I'm going to have to adjust to "quiet" once my Kioti NX5510 arrives; it's a cab model, so it being a CR engine is a good thing. But... I still like the sound of older diesels as they give you more of the feel that they're doing work:D
As dpb800 notes, you will continually find uses for a tractor. Seems that any time I go to do something I think whether the tractor can be utilized. Tractors are the MacGyver of machines:thumbsup:
/ New acerage need tractor #28
My open station Kubota L3560/3-cylinder 'Grand L' is not loud. However, I consistently wear hearing protection to preserve my hearing at age 69.
In four Florida cooler months I wear ear muffs over a long-bill baseball cap. Ear muffs protect my hearing and my external ears from sunburn/cancer. There is some variation between muff brands and models; not too much.
In the eight Florida hot months I wear in-ear plugs while wearing a wide brim straw hat for greater sun protection. There are a hundred plus brands and models of in-ear plugs sold on eBay. After trialling numerous models procured via eBay, I found one type both comfortable in my ears and effective, which I buy in bulk, cheap. Properly fitting plugs attenuate tractor noise more effectively than muffs.
Wide brim straw hats are $11 at Walmart. I decorate mine with $40 military cap badges, XIVth Bengal Lancers (WWI) being my favorite.
Save your body now, because you pay later.
I have friends whose Dermatologists whittle their ears, scalps or noses every 90 days. Ugly.
I am still beautiful.
/ New acerage need tractor #29
Speaking of hearing protection, anyone use noise-canceling stuff? I was contemplating this as my Polaris Brutus is just horribly loud: mitigated because I'm not using it for extended periods of time.
Some of my hesitation toward using hearing protection is that I want to be able to listen for problems.
jeff9366, you don't have a canopy on your tractor? I don't think I could survive down there without one.
/ New acerage need tractor #30
No, I do not.
I bought one of the earliest L3560 tractors. Kubota still had some specs from the L3540 lingering on its web site, including folded height of ROPS @ 84".
When my L3560 arrived I was surprised to find folded ROPS height at 87". So I had to take it to my exceptionally skilled local welder, who sectioned the ROPS by 4". (Weld is almost invisible.) Even so, it barely, barely fits in my humidity controlled garage.
So a canopy is out. And thus the straw hat. I am accustomed to the heat and humidity of working in Florida. In the summer I start early and quit by 12:30 PM. During that period I drink at least two liters of cold liquid, from insulated bike rider's plastic containers.
I wonder if you could rig up a tarp would give you shade and not increase the height by very much
/ New acerage need tractor #32
As I do considerable 'cleanup' along walking paths, in yards and commons in my 400 acre community, which means getting off the tractor frequently, I prefer sun protection travel with my head.
Also, the community is upscale. My wife has no problem with me tractoring but she wants me to start the day in pressed work clothes (her job) and she wants a new straw hat on my head twice per year. She prefers implements match the color of the tractor. A tarp will not do.
This is a wander, but I highly recommend Red Kap brand 100% cotton work clothes, which are make you sweat less than work clothes with even a small synthetic content. Short sleeve shirts $25. Also excellent insulated vests, available in LONG. Some Red Cap offerings are 100% cotton, some not. I only buy 100% cotton. Local internet distributors in each region of the USA. Search local for your pricing.
The only other source for 100% cotton is Duluth Trading, but Duluth asks $65 for their 100% cotton work shirts.
http://www.redkap.com/Products/Details/358040?product=Mens-Wrinkle-Resistant-Cotton-WorkShirt
/ New acerage need tractor #35
A friend of mine (who is 70) rides a Harley. He used to wear a helmet, but has recently switched to a leather brimmed hat with a wire in the rim. He likes it because he can shape it so no sun touches his face at all. He's scared $hitle$$ of skin cancer.
I tried telling him that I'm sure his dermatologist would advise him to wear the helmet, the motorcycle (or ratherer the pavement) being a more immediate danger than the sun, but he won't hear anything of it.
Just thought you guys might get a laugh outta that while we're on the topic. I know I did.
/ New acerage need tractor #36
Sun protecting lotions come in various strengths: SPF30, SPF50, etc.
The numbers are the hours of effective sun protection. My dermatologist says SPF30 is sufficient, THEN BATHE. :laughing:
/ New acerage need tractor #37
Hey beautiful Jeff, I checked out the Red Kap stuff, and I like the idea of buying it via Amazon Prime... very affordable if the quality is there! Speaking of dermatologists, my buddy who lives on Maryland's Eastern Shore, amongst watermen who spend their lives working on the water, has told me horror stories about skin cancers, and cataracts caused by sun exposure. He became a fan of Rayban sunglasses many years ago, and wears them always. The every 90 day visits to get pieces cut off and out rings true, from what he's told me.
I see kubota has now 0% financing for 84 months. That's interesting
/ New acerage need tractor #39
I think that might be a little to large
Haha, i remember when 10 acres seemed like more, which it is plenty of land i like the 5 series for lift capacity. The 4 series are nice, bit smaller but big enough to not out grow it imho. Show pics of whatever you buy. Have you checked mahindra, they seem very nice and competitive. I highly recommend you atleast see one in person before buying. Im going mahindra for my next tractor. Jd is getting too pricey for me and other companies are moving into the competition with good equipment
I did the mahindra was the first I checked out. I gotta go see massey yet and kiota
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
Caterpillar D8R/D9R Service Manuals (A63117)
Caterpillar...
