NEW 50HST
/ NEW 50HST #41
In addition to above, when you drill the holes in the bucket sides, drill them towards the front of the slot on the toothbar, then you can loosen them a little, pull the tooth bar forward and flip it into the bucket so you can backdrag smooth.
I learned this just a few hours AFTER my dealer drilled mine (towards the rear). :eek:
David
30 minutes with my welder , grinder,flap disk (to blend with) and a drill bit, and we could fix you right up. If you had a shot of spray paint, no one would ever know;)
James K0UA
/ NEW 50HST #42
Weld them shut and drill some new ones!:laughing:
James K0UA
Yes guys,
A welder IS on my list... Someday I WILL get one...
I PROMISE!
:D
David
/ NEW 50HST #43
David welding holes shut with a stick welder does take some practice. Best not be the first job you tackle right out of the box.. Holes are easy to make in metal with a stick welder, but it takes a little finesse to weld them shut. Not bad mind you but just not the first time you strike an arc. I sure wish you lived just down the road, I would like to help you with a lot of these type of things, but dang it you live so far away!
James K0UA
/ NEW 50HST #44
James K0UA
We need to find you a transfer to DC area!! :D
Tractor Parties at my place when you do! :D
Be well,
David
PS - CJONE, sorry for hijacking your thread sir!
/ NEW 50HST #45
MossflowerWoods said:
Yes guys,
I PROMISE!
:D
David
Even the $100 flux core machine at HF would do a fine job. A propane torch and brazing rod would be acceptable. Heck, even JB Weld would do it!
/ NEW 50HST #46
James K0UA
It wouldn't be hard if you stuck a thick piece of copper or brass behind the hole. Then use a very small rod to fill the hole and remove the backing material. I have a thick copper heat sink from HF that is designed for this sort of thing. I do agree that trying to fill just an empty hole in thin gauge metal is not for novices but with a backing plate of nonweldable material it shouldn't be tough.
/ NEW 50HST #47
IT,
Honestly it is SOOOO far down my list of projects right now that I will likely be a mediocre welder by the time I get to it...
I don't have a honey do list, I have a honey
doooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooox8
list.
David
/ NEW 50HST #48
IT,
list.
David
Been there and still doing that.
/ NEW 50HST
Be well,
David
No problem at all!! I will make the same offer to anyone who is close by as far as welding. I have a mig, stick machine and torches. CJ
Kuhn FC400RG (A60462)
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63118)
2004 Cadillac...
KBH Tender Trailer (A63118)
KBH Tender Trailer...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2006 Miller Built Gooseneck Trailer (A63116)
2006 Miller Built...
John Deere Hood Guard (A63116)
John Deere Hood...
