NEW 50HST
/ NEW 50HST #41
In addition to above, when you drill the holes in the bucket sides, drill them towards the front of the slot on the toothbar, then you can loosen them a little, pull the tooth bar forward and flip it into the bucket so you can backdrag smooth.
I learned this just a few hours AFTER my dealer drilled mine (towards the rear). :eek:
David
30 minutes with my welder , grinder,flap disk (to blend with) and a drill bit, and we could fix you right up. If you had a shot of spray paint, no one would ever know;)
James K0UA
/ NEW 50HST #42
Weld them shut and drill some new ones!:laughing:
James K0UA
Yes guys,
A welder IS on my list... Someday I WILL get one...
I PROMISE!
:D
David
/ NEW 50HST #43
David welding holes shut with a stick welder does take some practice. Best not be the first job you tackle right out of the box.. Holes are easy to make in metal with a stick welder, but it takes a little finesse to weld them shut. Not bad mind you but just not the first time you strike an arc. I sure wish you lived just down the road, I would like to help you with a lot of these type of things, but dang it you live so far away!
James K0UA
/ NEW 50HST #44
James K0UA
We need to find you a transfer to DC area!! :D
Tractor Parties at my place when you do! :D
Be well,
David
PS - CJONE, sorry for hijacking your thread sir!
/ NEW 50HST #45
MossflowerWoods said:
Yes guys,
I PROMISE!
:D
David
Even the $100 flux core machine at HF would do a fine job. A propane torch and brazing rod would be acceptable. Heck, even JB Weld would do it!
/ NEW 50HST #46
James K0UA
It wouldn't be hard if you stuck a thick piece of copper or brass behind the hole. Then use a very small rod to fill the hole and remove the backing material. I have a thick copper heat sink from HF that is designed for this sort of thing. I do agree that trying to fill just an empty hole in thin gauge metal is not for novices but with a backing plate of nonweldable material it shouldn't be tough.
/ NEW 50HST #47
IT,
Honestly it is SOOOO far down my list of projects right now that I will likely be a mediocre welder by the time I get to it...
I don't have a honey do list, I have a honey
doooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooox8
list.
David
/ NEW 50HST #48
IT,
list.
David
Been there and still doing that.
/ NEW 50HST
Be well,
David
No problem at all!! I will make the same offer to anyone who is close by as far as welding. I have a mig, stick machine and torches. CJ
2018 Volkswagen Tiguan SUV (A64557)
2018 Volkswagen...
1024 (A63111)
1024 (A63111)
2022 EZ-GO ELITE...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Anthem...
2022 EZ-GO ELITE...
