New 5065e
/ New 5065e #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
My new 5065e with 553 , global carrier, HD bucket
/ New 5065e
Not good at Pics. When I attach them they rotate. 90 degrees?
/ New 5065e #4
I'll bet you took photo with your phone and that's one drawback of a cellphone camera.
/ New 5065e #5
That is some steep ground you got, you must have mountain goat in you or something. :D
Nice tractor BTW!
/ New 5065e
Picked up a new Woods DMH6 , 6 ft disc harrow painted Green today. That goes with my 5065e, MFWD, 553 with global carrier and HD bucket, Bush Hog 296 (red) and Frontier Middle buster. Got all since Thursday. Got 9 hrs time in 3 days. I have never had a tractor and am delighted . I am maintaining roads and fire breaks, food plots and brush pile work. The Bush Hog cutter is awesome and a good match with 5065. The 553 exceeds my expectations. Have not hooked up Woods disc yet but sure it will be great for food plots. 1st week of tractor ownership has been great. I wear my JD hat proudly. But am impressed with BH 296 and value/quality of Woods disc.
/ New 5065e #7
You got some good gear, fun ain't it.
/ New 5065e
Yes. I just got my 80 acres in 2009 and I turn 55 this month. Love to hunt with my 2 boys (26 and 30). There is no feeling of being satisfied and connected to the earth like having your own land AND being able to tend to it. I know 80 acres isn't that much but there is nothing I enjoy more than working the land. The tractor and implements just makes it a lot more fun. If I had a dozer I probably would get fired for never going to work!
/ New 5065e #9
Enjoy it! We have a 10 acre tract of pasture, trees and lawn we live on and 67 acre tract of timber to hunt on an hour and a half away. We keep the 10 pristine and the 67 for fun.
/ New 5065e #10
9 hours great. Be sure to check the torque of your wheels and loader mount. not kidding. Enjoy.
/ New 5065e
Thanks but I have a question. My torque wrench has a max torque of 200 ft lbs (first tractor). Don't have air impact wrench or power at my property. Do I just get a manual (non-air) torque wrench that has longer handle and goes to 400 ft lbs?
/ New 5065e
Plus, with the deep insets (nut may be 10 inches inset from plane of tire) on wheels, you won't be able to apply torque with a 1 handle wrench because the offset will make the socket roll off the nut. Is this wheel torquing exercise only possible with an air impact wrench?
/ New 5065e #14
A set of inch drive sockets with a one foot extension is the way to go if you don't have impact/air wrench setup. The ratchet for those usually has about a 30" long handle and the sockets are six sided not twelve point and will stay on the nut. Hold the ratchet head in line so the handle stays square to the rim when applying force. A one inch drive torque wrench would also have a long handle but isn't cheap.
Not having one of those at hand I just put my 240 pounds bearing down on the thirty inch handle of that ratchet and get them gud,n,tight.
/ New 5065e
23500 for 5065e, MFWD
5850 for 553 with global carrier & HD Bucket
2795 for bush hog 296 with chains front and rear
1550 for Woods 6 ft cutter, DMH6
/ New 5065e #16
Congratulations. Interested to know how it goes for you.
Just saw one of these on Friday and liked the dealer. Was originally thinking of a Kioti RX6010, but all the dealers in the area are non-responsive. I guess that also means when there is a problem to expect the same.
Similar situation, 100 acres on a mountain in NH. Want to clear land for animals, house in 10 years and to improve the grouse habitat. I don't have a 10x10 area that is flat or free of granite.
/ New 5065e
Thanks for advice. Let me clarify: the 12 inch extension is to accommodate the inset dish and allow force to be applied perpindicular to wrench so you don't try to round off nut head. Also are the nuts metric or English ?
/ New 5065e #18
Correct on the purpose of the extension. The rim bolts on mine are English but much or the tractor is metric so you better buy a set with both. The owners manual gives values for both unified inch and metric but I see no table of what is used where.
/ New 5065e
I did see M16 and M20s called out in 553 manual for loader frame so I know it's metric but the tractor manual does not specify size of wheel nuts like you said . Man, what a pain if you need both? I have both up through 1/2 inch drive but this tractor is heavier duty than anything I have owned!
/ New 5065e #20
It is a pain to have both sets of sizes but in the larger drive sizes you will never wear them out and only other tractor owners will want to borrow them so they should last you forever. A few tools, oil filter wrench, grease gun, socket set etc. are not that much to take care of a $30K tractor properly.
Ford F-450 (A63118)
Ford F-450 (A63118)
2018 Dodge 5500 Bucket Truck 4WD (A63118)
2018 Dodge 5500...
2005 Chevrolet Silverado 2500HD Pickup Truck, VIN # 1GCHK23205F931883 (A61165)
2005 Chevrolet...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63118)
2006 Cadillac GM...
2016 JCB 510-56 10000 LB Telehandler (A64047)
2016 JCB 510-56...
