New 425…Float feature…
   / New 425…Float feature… #1
Modrob
Power Trac
On our new 425, I’m having trouble (typical for me having troubles😆) with the Float feature. I had found it on the old 2001 unit by accident and found it to be easy to use. (Only glitch was sometimes the joystick would “fall out” of its Float position, but I’m sure that 20-plus years had a lot to do with that.)
I’m not having the same kind of results with this new one—seems no matter what approach I make it tends to shortly dig in, and abruptly stop me. I know it should be simple but again typical for me, I’m struggling with it. So, any tips? (No matter how simple, hit me with your comments anyway—could be I’m looking over the simplest detail😊)
   / New 425…Float feature… #2
What are you using float for?
I only use it for things like dragging a bucket backwards to level the arena. I do not use it for forward motion because the tractor tries pop over the implement.
Just to confirm: does your new 425 control lever stays in float ok?
All the best,
Peter
   / New 425…Float feature… #3
I agree.... you can't move forward with the bucket lip engaged with the ground in float because the machine will want to drive over the implement as soon as it bites. Same thing can happen in heavy packed snow banks.
I use float with the mower and brush cutter, or when sliding my forks under a pallet.
And, like mentioned, I sometimes use it for back dragging the bucket. I just did that yesterday when final leveling a bed to plant canna lilies in.
   / New 425…Float feature… #4
Most people do not use float for loading material into the bucket. Tip the bucket slightly down with some down pressure, drive forward, as soon as the cutting edge digs in, tip the bucket back slightly more toward a level bucket. As it digs in more you lift it slightly to get weight on the wheels for traction and not to overbite and dig too deep. It takes practice.
If the control pops out of float, it may need adjustment from the hand-lever to the valve linkage. That is assuming the control lever is reaching its extreme travel limit before it pushes the spool in the valve fully into the float position.
   / New 425…Float feature… #5
Non-Power Trac owner here with a question - Does the float feature on a Power Trac work like it does on a tractor, i.e., when you engage float on my 2520, the loader "floats" up and down, but the bucket tilt is locked where you last left it.
On my tractor, I set the bucket lip about an inch off the ground, then engage float to plow snow and it does not dig in because it is riding on the heel of the bucket.
Just curious.
Thanks.
   / New 425…Float feature… #6
Justs curious.
Thanks.
As described, yes.
Personally, I find that on my PT, the PT still tends to ride up over the bucket when doing as you describe, probably due to the differences in where the FEL is attached relative to the bucket lip.
For me, picking a slight angle to the bucket and then adjusting the height as needed going along by "sensing" the force seems to be more effective. I agree that is a "by the seat of the pants" style, but between hearing the motor load, and feeling the changes in load/speed of the tractor, it seems to work for me. For the record, I don't consider myself terribly adept at "rub your tummy / pat your head" sort of things.
All the best,
Peter
   / New 425…Float feature… #7
Last fall I dug out a 50' row of canna lily bulbs with my FEL bucket. I positioned the machine perpendicular to the row, scooped them out with my large bucket, backed away from the trench, dumped the bucket on the lawn next to the trench, repeated until done.
After I was done picking the bulbs out of the piles by hand I had to put the dirt back in the trench.
Again, positioned the machine perpendicular to the trench, put the bucket in float, dumped/curled it back and forth until I could see it level (you can tell when it's on the flat by doing this a couple times and watching the bucket rock), then pulled it out of float and pushed the piles back into the trench. Got most of the dirt out of the lawn and back in the trench.
If I have to plow snow with the bucket, I do as mentioned above, put the bucket in float, dump/curl until it's level, then curl it back a smidge so I know the leading edge is off the driveway about an inch. Since our driveway is paved, I can just move along in float of the snow is light. If it's wet and heavy, I have to pull it out of float or it will tend to climb up over the bucket.
I much prefer the power angle snow blade with gauge wheels. I can tilt the blade forward enough that it'll ride over and cracks in float, or I can tip it up on the gauge wheels if I have to go into the grass.
As mentioned, a bit of seat time and you'll figure it out. (I had to read a book :ROFLMAO: )
   / New 425…Float feature… #8
As described, yes.
All the best,
Peter
Thanks for that description. I have to do the same thing, watch the bucket and if it starts to ride up, tilt down a little and vice versa.
   / New 425…Float feature… #9
Having both traditional tractors along with Power Tracs, the design of the PT makes it more likely to ride up over the bucket mostly because the PTs are very light on the front tires. Unlike normal tractors with the engine in the front, a PT has a rear engine and doesn't need counter weights in the rear, but once you put the loader in float, it now takes away a lot of front weight yet still having the engine weight somewhat behind the rear tires (fulcrum) which actually lifts weight off the front.
Float is really best at back-dragging buckets and blades and for mowers.
On any machine, a free floating loader bucket is at the mercy of the bucket/cutting edge angle. Too much and it will head to China, not enough and you will have a bucket just as empty as it was when you started the attempted cut.
   / New 425…Float feature… #10
... not enough and you will have a bucket just as empty as it was when you started the attempted cut.
:ROFLMAO: I remember several times when I thought I was scooping something up, felt really good about it, then went to dump and there was nothing in the bucket! Completely disappointed in myself! :ROFLMAO: Aww man! :ROFLMAO:
2020 CAT 308 (A53317)
2025 J & C Suppliers S/A 14ft Enclosed Trailer (A56859)
2025 J & C...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
2016 Ford Explorer SUV (A56859)
2016 Ford Explorer...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
New/Unused AGT Industrial Quick Attach Auger with 3 Bits (A57454)
New/Unused AGT...
