New 4110
/ New 4110 #1
tld
Boston, GA
JD 2025r
Just took delivery of my new JD 4110 with BH RD60 finish mower. Prior to delivery they had to put about 200 lb of wieght in the front to balance it out. Even now when I raise the mower too fast it almost takes the wheels off the ground.
Is this mower too much for this tractor?
/ New 4110 #2
No. Most compact tractors without FEL will require front end weights with a rear mower. It sounds as if you may need a little more front end weight. With my old B7100 I usually added about 150lbs without FEL.
/ New 4110 #3
I put 165 pounds on the nose of my B-7500 to counter balance my Woods RD 6000. The tractor handles the mower just fine and if memory serves your tractor is the same HP and PTO HP as mine. Good luck have fun and enjoy that new tractor./w3tcompact/icons/grin.gif
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2021 KENWORTH T680...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
(3) Tires (A65640)
(3) Tires (A65640)
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
