Buying Advice New 4066R with SSQA
/ New 4066R with SSQA #1
rkenne
Sinton, TX
2007 TC40da
I have decided to buy a 4066R but prefer skid steer quick attach which I can order with a new loader. The dealer could not find a deere bucket to go on the loader without just ordering one that comes factory on a skid steer. I love the looks of the heavy duty bucket with loops but I believe it is only available with John Deere attachments. Anyone have any experience with this or advice?
/ New 4066R with SSQA #2
Because you have chosen the construction grade SS coupler, Deere offers the worksite pro construction grade buckets. Your options are to paint the construction bucket green, and add hooks. Or modify the HD agricultural bucket to fit on the SS coupler. Alternatively you could custom order a bucket from somebody like werk-brau to have the coolest looking bucket on the block.
/ New 4066R with SSQA #3
This is 100% correct.
/ New 4066R with SSQA #4
The loader bucket you want is actually a worksite Pro bucket that they use on the 110tlb. They are a little different shape than a true skid steer bucket and they don’t have the step on the top.
The part number I have for my 4720 400cx loader (with skid steer mounts)is LVB25342. It is a 72 inch heavy duty bucket with a bolt on cutting edge. It is nearly indestructible. It weighs about 430 pounds.
Don’t forget to weld on some of Ken’s grab hooks (I have 3)
/ New 4066R with SSQA #5
Thought I would mention you will need to subtract the weight of the bucket from the FEL lift capacity to get your lift limits. Just make sure you are ok with those numbers when getting a heavier bucket and SSQA. They both add weight.
Thanks for the info. I think that'll work. Do you have any pics?
I meant pictures of your tractor with this bucket on it
/ New 4066R with SSQA #9
You probably meant MY tractor, not HIS tractor:laughing:
/ New 4066R with SSQA #10
I did order my Massey with the HD bucket which is just a skid steer bucket. Even says "Type: SKID STEER" on the label
How about self leveling vs non Self leveling?
/ New 4066R with SSQA #14
Some of that choice is just a matter of personal preference. I very much like my 400cx (self leveling).
I would say if you plan to use pallet forks or a bale spear, then you would 100% prefer a self leveling.
If you plan to mostly use a grapple or bucket, it wouldn't matter as much.
/ New 4066R with SSQA #15
Having one with and one without, I totally agree.
What's the cost of this option?
/ New 4066R with SSQA #17
If you aren't doing a LOT of fork work or big hay bale work I wouldn't do it. Normal loader work it's not needed.
/ New 4066R with SSQA #18
I’m not up on the loader the loader specs for the new 4 series John Deere’s, but when I got my 4720 with the 400cx loader, I believe they were advertising 20% greater lift with the 400cx (self leveling) vs 400x (non self leveling).
21ft Gooseneck Hay/Pine Straw Trailer (A65563)
21ft Gooseneck...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
GEHL TELESCOPIC FORKLIFT (A65053)
GEHL TELESCOPIC...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
